| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 93 Shop Shark | | Shop Shark Joined: Feb 2017 Posts: 93 | It is a 59, and I believe that it does. It looks like this graphic: http://chevy.oldcarmanualproject.com/shop/1959trucksup/59ctsms0803.htmlI am sure there are some crusty bits, and odds are the motor is junk like everyone is saying. I had to tap the stuck lifters and valves loose with a hammer, at least one of the rods may be slightly bent. That being said, if I can get it to fire, I am going to run it long enough to get warm, then shut down, drain the oil, and change the filter (which I already bought). If it runs, great, I am ahead of the game. If not, it was a good hands on learning experience for me, and I will either re-build, or put my fathers motor in. Actually, I think I will put my fathers motor in so I can drive the truck and work on other things, and rebuild the existing motor for the long term. Does this 261 have full flow filtration? Would suspect there could still be some crusty bits hiding somewhere. Having the full flow in place might catch some of the bigger ones.
1959 Chevy Viking. Belonged to my Great Grandfather
Entire Thread
Is the motor frozen, or just stuck? "it ran when I parked it there"
| Patagoniadave | 02/28/2017 3:27 PM |
Re: Is the motor frozen, or just stuck? "it ran when I parked it there"
| JW51 | 02/28/2017 3:43 PM |
| fixit1958 | 02/28/2017 4:12 PM |
| Patagoniadave | 02/28/2017 4:27 PM |
| panic | 02/28/2017 4:36 PM |
| Hotrod Lincoln | 02/28/2017 5:14 PM |
| Patagoniadave | 02/28/2017 5:44 PM |
| fixit1958 | 02/28/2017 6:16 PM |
| Patagoniadave | 02/28/2017 6:37 PM |
| Justhorsenround | 02/28/2017 7:18 PM |
| Patagoniadave | 02/28/2017 7:27 PM |
| Hotrod Lincoln | 02/28/2017 8:06 PM |
| Volfandt | 02/28/2017 8:37 PM |
| Patagoniadave | 02/28/2017 8:45 PM |
| bartamos | 02/28/2017 9:02 PM |
| Patagoniadave | 02/28/2017 9:20 PM |
| bartamos | 02/28/2017 9:23 PM |
| Patagoniadave | 02/28/2017 9:30 PM |
| JW51 | 02/28/2017 10:38 PM |
| bartamos | 02/28/2017 11:06 PM |
| JW51 | 03/01/2017 12:29 AM |
| Hotrod Lincoln | 03/01/2017 1:01 AM |
| bartamos | 03/01/2017 1:09 AM |
| Hotrod Lincoln | 03/01/2017 1:22 AM |
| bartamos | 03/01/2017 1:28 AM |
| Patagoniadave | 03/01/2017 4:12 AM |
| Volfandt | 03/01/2017 2:17 AM |
| Hotrod Lincoln | 03/01/2017 4:35 AM |
| bartamos | 03/01/2017 5:37 AM |
| Patagoniadave | 03/01/2017 3:17 PM |
| Patagoniadave | 04/05/2017 7:24 PM |
| Hotrod Lincoln | 03/01/2017 5:46 AM |
| moparguy | 03/01/2017 2:42 PM |
| Volfandt | 03/01/2017 2:53 PM |
| Justhorsenround | 03/01/2017 3:34 PM |
| Patagoniadave | 03/01/2017 4:19 PM |
| Hotrod Lincoln | 03/01/2017 4:53 PM |
| yar | 03/01/2017 5:22 PM |
| bartamos | 03/01/2017 6:39 PM |
| Patagoniadave | 03/01/2017 7:25 PM |
| bowtietim | 03/02/2017 4:51 AM |
| Patagoniadave | 03/02/2017 2:53 PM |
| bartamos | 03/05/2017 6:14 AM |
| fixit1958 | 03/05/2017 3:00 PM |
| Patagoniadave | 03/05/2017 4:35 PM |
| Justhorsenround | 03/05/2017 5:27 PM |
| fixit1958 | 03/05/2017 5:40 PM |
| bartamos | 03/05/2017 6:20 PM |
| moparguy | 03/06/2017 4:22 AM |
| 52Carl | 03/08/2017 2:54 AM |
| moparguy | 03/08/2017 3:51 AM |
| Hotrod Lincoln | 03/08/2017 4:16 AM |
| Patagoniadave | 03/09/2017 3:19 PM |
| bartamos | 03/09/2017 6:58 PM |
| JW51 | 03/09/2017 7:19 PM |
| Patagoniadave | 03/09/2017 7:37 PM |
| JW51 | 03/09/2017 7:39 PM |
| Patagoniadave | 03/09/2017 8:03 PM |
| bartamos | 03/09/2017 7:40 PM |
| JW51 | 03/09/2017 7:44 PM |
| bartamos | 03/09/2017 7:53 PM |
| JW51 | 03/09/2017 8:10 PM |
| Volfandt | 03/09/2017 11:37 PM |
| JW51 | 03/10/2017 12:59 AM |
| bartamos | 03/10/2017 1:19 AM |
| fixit1958 | 03/10/2017 4:10 PM |
| Patagoniadave | 03/10/2017 4:38 PM |
| Mike B | 03/11/2017 5:49 AM |
| Patagoniadave | 03/12/2017 6:09 AM |
| truckernix | 03/12/2017 1:26 PM |
| Patagoniadave | 03/13/2017 3:09 PM |
| JW51 | 03/12/2017 3:17 PM |
| fixit1958 | 03/12/2017 3:51 PM |
| MikeE | 03/12/2017 5:22 PM |
| bartamos | 03/12/2017 5:51 PM |
| 52Carl | 03/13/2017 12:49 AM |
| Patagoniadave | 03/13/2017 3:07 PM |
| Patagoniadave | 03/13/2017 4:04 PM |
| Hotrod Lincoln | 03/13/2017 4:25 PM |
| Patagoniadave | 03/13/2017 4:34 PM |
| Justhorsenround | 03/13/2017 4:43 PM |
| Patagoniadave | 03/13/2017 4:57 PM |
| Hotrod Lincoln | 03/13/2017 4:48 PM |
| Patagoniadave | 03/22/2017 3:14 PM |
| Hotrod Lincoln | 04/05/2017 7:29 PM |
| JW51 | 04/05/2017 9:49 PM |
| Patagoniadave | 04/05/2017 9:57 PM |
| JW51 | 04/05/2017 10:11 PM |
| Patagoniadave | 04/05/2017 10:17 PM |
| Hotrod Lincoln | 04/05/2017 11:31 PM |
| JW51 | 04/06/2017 2:04 AM |
| Patagoniadave | 04/06/2017 3:28 AM |
| Patagoniadave | 04/25/2017 3:44 PM |
| truckernix | 04/25/2017 3:55 PM |
| Patagoniadave | 04/25/2017 4:15 PM |
| Patagoniadave | 04/26/2017 4:47 PM |
| Hotrod Lincoln | 04/26/2017 5:08 PM |
| Patagoniadave | 04/26/2017 5:32 PM |
| Howies551Ton | 04/27/2017 8:22 PM |
| Patagoniadave | 04/27/2017 8:37 PM |
| Hotrod Lincoln | 04/27/2017 9:23 PM |
| Patagoniadave | 04/27/2017 10:16 PM |
| Hotrod Lincoln | 04/27/2017 11:24 PM |
| Pre '68 Dave | 04/27/2017 11:53 PM |
| Patagoniadave | 04/28/2017 3:34 PM |
| Hotrod Lincoln | 04/28/2017 3:56 PM |
| Patagoniadave | 04/28/2017 4:44 PM |
| Hotrod Lincoln | 04/28/2017 5:25 PM |
| 52Carl | 04/29/2017 4:59 AM |
| Patagoniadave | 05/01/2017 4:01 PM |
| JW51 | 05/01/2017 5:50 PM |
| Patagoniadave | 05/01/2017 6:06 PM |
| Hotrod Lincoln | 05/01/2017 6:47 PM |
| Patagoniadave | 05/01/2017 6:52 PM |
| 52Carl | 05/02/2017 2:46 AM | |
