| | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | I just did exactly the same thing with a 1946-vintage 216 that I've had for several years- - - - -no idea how long it sat idle before I got it. It took 3 months of soaking (with Kroil) and prying to get enough of a turn of the flywheel to get all the clutch bolts removed. I've got the bellhousing sold, so I MUST get the flywheel off to reach the bolts hidden behind it. It hasn't quite made a full turn yet, but it's close.
I don't plan to try to start that one- - - -eventually I'll do a full teardown and rebuild. I'm one of those old dinosaurs who believes 216's are useful for something other than boat anchors. I really enjoy scraping Babbit bearings and shimming connecting rods- - - -I'm just weird that way!
BTW- - - -the chisel-shaped end of a shepherd's crook wrecking bar about 3 feet long is just right for getting a good engagement with a flywheel ring gear if you've got room to swing it. Jerry
Entire Thread
Is the motor frozen, or just stuck? "it ran when I parked it there"
| Patagoniadave | 02/28/2017 3:27 PM |
Re: Is the motor frozen, or just stuck? "it ran when I parked it there"
| JW51 | 02/28/2017 3:43 PM |
| fixit1958 | 02/28/2017 4:12 PM |
| Patagoniadave | 02/28/2017 4:27 PM |
| panic | 02/28/2017 4:36 PM |
| Hotrod Lincoln | 02/28/2017 5:14 PM |
| Patagoniadave | 02/28/2017 5:44 PM |
| fixit1958 | 02/28/2017 6:16 PM |
| Patagoniadave | 02/28/2017 6:37 PM |
| Justhorsenround | 02/28/2017 7:18 PM |
| Patagoniadave | 02/28/2017 7:27 PM |
| Hotrod Lincoln | 02/28/2017 8:06 PM |
| Volfandt | 02/28/2017 8:37 PM |
| Patagoniadave | 02/28/2017 8:45 PM |
| bartamos | 02/28/2017 9:02 PM |
| Patagoniadave | 02/28/2017 9:20 PM |
| bartamos | 02/28/2017 9:23 PM |
| Patagoniadave | 02/28/2017 9:30 PM |
| JW51 | 02/28/2017 10:38 PM |
| bartamos | 02/28/2017 11:06 PM |
| JW51 | 03/01/2017 12:29 AM |
| Hotrod Lincoln | 03/01/2017 1:01 AM |
| bartamos | 03/01/2017 1:09 AM |
| Hotrod Lincoln | 03/01/2017 1:22 AM |
| bartamos | 03/01/2017 1:28 AM |
| Patagoniadave | 03/01/2017 4:12 AM |
| Volfandt | 03/01/2017 2:17 AM |
| Hotrod Lincoln | 03/01/2017 4:35 AM |
| bartamos | 03/01/2017 5:37 AM |
| Patagoniadave | 03/01/2017 3:17 PM |
| Patagoniadave | 04/05/2017 7:24 PM |
| Hotrod Lincoln | 03/01/2017 5:46 AM |
| moparguy | 03/01/2017 2:42 PM |
| Volfandt | 03/01/2017 2:53 PM |
| Justhorsenround | 03/01/2017 3:34 PM |
| Patagoniadave | 03/01/2017 4:19 PM |
| Hotrod Lincoln | 03/01/2017 4:53 PM |
| yar | 03/01/2017 5:22 PM |
| bartamos | 03/01/2017 6:39 PM |
| Patagoniadave | 03/01/2017 7:25 PM |
| bowtietim | 03/02/2017 4:51 AM |
| Patagoniadave | 03/02/2017 2:53 PM |
| bartamos | 03/05/2017 6:14 AM |
| fixit1958 | 03/05/2017 3:00 PM |
| Patagoniadave | 03/05/2017 4:35 PM |
| Justhorsenround | 03/05/2017 5:27 PM |
| fixit1958 | 03/05/2017 5:40 PM |
| bartamos | 03/05/2017 6:20 PM |
| moparguy | 03/06/2017 4:22 AM |
| 52Carl | 03/08/2017 2:54 AM |
| moparguy | 03/08/2017 3:51 AM |
| Hotrod Lincoln | 03/08/2017 4:16 AM |
| Patagoniadave | 03/09/2017 3:19 PM |
| bartamos | 03/09/2017 6:58 PM |
| JW51 | 03/09/2017 7:19 PM |
| Patagoniadave | 03/09/2017 7:37 PM |
| JW51 | 03/09/2017 7:39 PM |
| Patagoniadave | 03/09/2017 8:03 PM |
| bartamos | 03/09/2017 7:40 PM |
| JW51 | 03/09/2017 7:44 PM |
| bartamos | 03/09/2017 7:53 PM |
| JW51 | 03/09/2017 8:10 PM |
| Volfandt | 03/09/2017 11:37 PM |
| JW51 | 03/10/2017 12:59 AM |
| bartamos | 03/10/2017 1:19 AM |
| fixit1958 | 03/10/2017 4:10 PM |
| Patagoniadave | 03/10/2017 4:38 PM |
| Mike B | 03/11/2017 5:49 AM |
| Patagoniadave | 03/12/2017 6:09 AM |
| truckernix | 03/12/2017 1:26 PM |
| Patagoniadave | 03/13/2017 3:09 PM |
| JW51 | 03/12/2017 3:17 PM |
| fixit1958 | 03/12/2017 3:51 PM |
| MikeE | 03/12/2017 5:22 PM |
| bartamos | 03/12/2017 5:51 PM |
| 52Carl | 03/13/2017 12:49 AM |
| Patagoniadave | 03/13/2017 3:07 PM |
| Patagoniadave | 03/13/2017 4:04 PM |
| Hotrod Lincoln | 03/13/2017 4:25 PM |
| Patagoniadave | 03/13/2017 4:34 PM |
| Justhorsenround | 03/13/2017 4:43 PM |
| Patagoniadave | 03/13/2017 4:57 PM |
| Hotrod Lincoln | 03/13/2017 4:48 PM |
| Patagoniadave | 03/22/2017 3:14 PM |
| Hotrod Lincoln | 04/05/2017 7:29 PM |
| JW51 | 04/05/2017 9:49 PM |
| Patagoniadave | 04/05/2017 9:57 PM |
| JW51 | 04/05/2017 10:11 PM |
| Patagoniadave | 04/05/2017 10:17 PM |
| Hotrod Lincoln | 04/05/2017 11:31 PM |
| JW51 | 04/06/2017 2:04 AM |
| Patagoniadave | 04/06/2017 3:28 AM |
| Patagoniadave | 04/25/2017 3:44 PM |
| truckernix | 04/25/2017 3:55 PM |
| Patagoniadave | 04/25/2017 4:15 PM |
| Patagoniadave | 04/26/2017 4:47 PM |
| Hotrod Lincoln | 04/26/2017 5:08 PM |
| Patagoniadave | 04/26/2017 5:32 PM |
| Howies551Ton | 04/27/2017 8:22 PM |
| Patagoniadave | 04/27/2017 8:37 PM |
| Hotrod Lincoln | 04/27/2017 9:23 PM |
| Patagoniadave | 04/27/2017 10:16 PM |
| Hotrod Lincoln | 04/27/2017 11:24 PM |
| Pre '68 Dave | 04/27/2017 11:53 PM |
| Patagoniadave | 04/28/2017 3:34 PM |
| Hotrod Lincoln | 04/28/2017 3:56 PM |
| Patagoniadave | 04/28/2017 4:44 PM |
| Hotrod Lincoln | 04/28/2017 5:25 PM |
| 52Carl | 04/29/2017 4:59 AM |
| Patagoniadave | 05/01/2017 4:01 PM |
| JW51 | 05/01/2017 5:50 PM |
| Patagoniadave | 05/01/2017 6:06 PM |
| Hotrod Lincoln | 05/01/2017 6:47 PM |
| Patagoniadave | 05/01/2017 6:52 PM |
| 52Carl | 05/02/2017 2:46 AM | |
