| | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Here's the deal. If Grandpa wants to pull it with the loader your going to have to do something drastic before he can get to it. Get a buddy or two to help out. Take all the plugs out! Put more penetrating oil in each cylinder. Put the truck in 3rd gear. Rock the truck back and forth by hand several times. Bet it breaks loose. If not let it soak longer and try again by hand. As Jerry said no pulling with another vehicle until its already loose. You will bend or break something. If you have to, handcuff Grandpa to his recliner until you get the motor loose then let him "help" you get it fired up. Good luck.
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne (Emily) ‘39 Dodge Business Coupe (Clarence) “I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
Entire Thread
Is the motor frozen, or just stuck? "it ran when I parked it there"
| Patagoniadave | 02/28/2017 3:27 PM |
Re: Is the motor frozen, or just stuck? "it ran when I parked it there"
| JW51 | 02/28/2017 3:43 PM |
| fixit1958 | 02/28/2017 4:12 PM |
| Patagoniadave | 02/28/2017 4:27 PM |
| panic | 02/28/2017 4:36 PM |
| Hotrod Lincoln | 02/28/2017 5:14 PM |
| Patagoniadave | 02/28/2017 5:44 PM |
| fixit1958 | 02/28/2017 6:16 PM |
| Patagoniadave | 02/28/2017 6:37 PM |
| Justhorsenround | 02/28/2017 7:18 PM |
| Patagoniadave | 02/28/2017 7:27 PM |
| Hotrod Lincoln | 02/28/2017 8:06 PM |
| Volfandt | 02/28/2017 8:37 PM |
| Patagoniadave | 02/28/2017 8:45 PM |
| bartamos | 02/28/2017 9:02 PM |
| Patagoniadave | 02/28/2017 9:20 PM |
| bartamos | 02/28/2017 9:23 PM |
| Patagoniadave | 02/28/2017 9:30 PM |
| JW51 | 02/28/2017 10:38 PM |
| bartamos | 02/28/2017 11:06 PM |
| JW51 | 03/01/2017 12:29 AM |
| Hotrod Lincoln | 03/01/2017 1:01 AM |
| bartamos | 03/01/2017 1:09 AM |
| Hotrod Lincoln | 03/01/2017 1:22 AM |
| bartamos | 03/01/2017 1:28 AM |
| Patagoniadave | 03/01/2017 4:12 AM |
| Volfandt | 03/01/2017 2:17 AM |
| Hotrod Lincoln | 03/01/2017 4:35 AM |
| bartamos | 03/01/2017 5:37 AM |
| Patagoniadave | 03/01/2017 3:17 PM |
| Patagoniadave | 04/05/2017 7:24 PM |
| Hotrod Lincoln | 03/01/2017 5:46 AM |
| moparguy | 03/01/2017 2:42 PM |
| Volfandt | 03/01/2017 2:53 PM |
| Justhorsenround | 03/01/2017 3:34 PM |
| Patagoniadave | 03/01/2017 4:19 PM |
| Hotrod Lincoln | 03/01/2017 4:53 PM |
| yar | 03/01/2017 5:22 PM |
| bartamos | 03/01/2017 6:39 PM |
| Patagoniadave | 03/01/2017 7:25 PM |
| bowtietim | 03/02/2017 4:51 AM |
| Patagoniadave | 03/02/2017 2:53 PM |
| bartamos | 03/05/2017 6:14 AM |
| fixit1958 | 03/05/2017 3:00 PM |
| Patagoniadave | 03/05/2017 4:35 PM |
| Justhorsenround | 03/05/2017 5:27 PM |
| fixit1958 | 03/05/2017 5:40 PM |
| bartamos | 03/05/2017 6:20 PM |
| moparguy | 03/06/2017 4:22 AM |
| 52Carl | 03/08/2017 2:54 AM |
| moparguy | 03/08/2017 3:51 AM |
| Hotrod Lincoln | 03/08/2017 4:16 AM |
| Patagoniadave | 03/09/2017 3:19 PM |
| bartamos | 03/09/2017 6:58 PM |
| JW51 | 03/09/2017 7:19 PM |
| Patagoniadave | 03/09/2017 7:37 PM |
| JW51 | 03/09/2017 7:39 PM |
| Patagoniadave | 03/09/2017 8:03 PM |
| bartamos | 03/09/2017 7:40 PM |
| JW51 | 03/09/2017 7:44 PM |
| bartamos | 03/09/2017 7:53 PM |
| JW51 | 03/09/2017 8:10 PM |
| Volfandt | 03/09/2017 11:37 PM |
| JW51 | 03/10/2017 12:59 AM |
| bartamos | 03/10/2017 1:19 AM |
| fixit1958 | 03/10/2017 4:10 PM |
| Patagoniadave | 03/10/2017 4:38 PM |
| Mike B | 03/11/2017 5:49 AM |
| Patagoniadave | 03/12/2017 6:09 AM |
| truckernix | 03/12/2017 1:26 PM |
| Patagoniadave | 03/13/2017 3:09 PM |
| JW51 | 03/12/2017 3:17 PM |
| fixit1958 | 03/12/2017 3:51 PM |
| MikeE | 03/12/2017 5:22 PM |
| bartamos | 03/12/2017 5:51 PM |
| 52Carl | 03/13/2017 12:49 AM |
| Patagoniadave | 03/13/2017 3:07 PM |
| Patagoniadave | 03/13/2017 4:04 PM |
| Hotrod Lincoln | 03/13/2017 4:25 PM |
| Patagoniadave | 03/13/2017 4:34 PM |
| Justhorsenround | 03/13/2017 4:43 PM |
| Patagoniadave | 03/13/2017 4:57 PM |
| Hotrod Lincoln | 03/13/2017 4:48 PM |
| Patagoniadave | 03/22/2017 3:14 PM |
| Hotrod Lincoln | 04/05/2017 7:29 PM |
| JW51 | 04/05/2017 9:49 PM |
| Patagoniadave | 04/05/2017 9:57 PM |
| JW51 | 04/05/2017 10:11 PM |
| Patagoniadave | 04/05/2017 10:17 PM |
| Hotrod Lincoln | 04/05/2017 11:31 PM |
| JW51 | 04/06/2017 2:04 AM |
| Patagoniadave | 04/06/2017 3:28 AM |
| Patagoniadave | 04/25/2017 3:44 PM |
| truckernix | 04/25/2017 3:55 PM |
| Patagoniadave | 04/25/2017 4:15 PM |
| Patagoniadave | 04/26/2017 4:47 PM |
| Hotrod Lincoln | 04/26/2017 5:08 PM |
| Patagoniadave | 04/26/2017 5:32 PM |
| Howies551Ton | 04/27/2017 8:22 PM |
| Patagoniadave | 04/27/2017 8:37 PM |
| Hotrod Lincoln | 04/27/2017 9:23 PM |
| Patagoniadave | 04/27/2017 10:16 PM |
| Hotrod Lincoln | 04/27/2017 11:24 PM |
| Pre '68 Dave | 04/27/2017 11:53 PM |
| Patagoniadave | 04/28/2017 3:34 PM |
| Hotrod Lincoln | 04/28/2017 3:56 PM |
| Patagoniadave | 04/28/2017 4:44 PM |
| Hotrod Lincoln | 04/28/2017 5:25 PM |
| 52Carl | 04/29/2017 4:59 AM |
| Patagoniadave | 05/01/2017 4:01 PM |
| JW51 | 05/01/2017 5:50 PM |
| Patagoniadave | 05/01/2017 6:06 PM |
| Hotrod Lincoln | 05/01/2017 6:47 PM |
| Patagoniadave | 05/01/2017 6:52 PM |
| 52Carl | 05/02/2017 2:46 AM | |
