| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,743 | I use a #0 or #1 heating tip from an Acetyline torch for vacuum leak checking. It's much easier to pinpoint the area being tested instead of using a relative wide stream of Propane. Jerry
