6 members (tclederman, TexasJim50, baldeagle, Peggy M, cmayna, 49choptop), 112 guests, and 4 robots.
Topics128,018
Posts1,055,341
Members48,419
#995868 12/31/2013 8:30 PM
have a 1950 3/4 ton p/u. I think I want to take out the old 216 engine. Two questions. What should I look for in a replacement; one that can mount up with little work. I have been offered a six cylinder from an 87 Camaro or firebird. Will that work? easily?
Thanks for the help. What should I do about a transmission? will the old one still work or should I replace that too?
evac34 #995869 12/31/2013 8:44 PM
Leo Offline
Moderator
Moderator
If you want something with little extra work, consider a 261. It's a direct bolt-in engine. I have one and am very happy with it.
evac34 #995872 12/31/2013 8:55 PM
A 235 is also a good choice. But to answer your question, no, ..only a 235-262 up to 1962 is a direct bolt in replacement. The later model inline series are dimensionally different and the mounts are too.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
evac34 #995874 12/31/2013 9:12 PM
The 6 cylinder motor from an '87 Camaro or Firebird is a V-6 type engine. The bellhousing that is used with that engine is different than the typical Chevrolet bellhousing. Not saying that it couldn't be installed but it would require a considerable amount of fabrication to do it. It would make more sense to find something to put in that requires less fabrication.
evac34 #995884 12/31/2013 10:03 PM
I would put a 700r4 or t5 with an open drive line. The t5 bolts up with little work. I would have gone with thautomatic if I had known I was going to do as much as I have done to my 54 .
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
evac34 #995928 01/01/2014 1:01 AM
A '55 and later 235/261 is not exactly a bolt in to a '50 as stated above. Some waterpump mod is required. It is a good swap though.
evac34 #995946 01/01/2014 1:54 AM
1 Offline
Anything can be made to work if you are willing to throw enough money at it, but the better choices are mentioned in the above posts, 235's or 261's.DO NOT SWEAT the waterpump modification, If I can do it, Anyone can do it. I think some people look at certain challenges as the glass is half empty. Jerry
