| | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 15 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 15 | Does anybody have a detailed picture of an original arm rest, I am in search of one and not quite sure what it will look like if i do find one thanks for any help on this. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Don't know if this helps or not? http://www.classicparts.com/Arm-Rests/products/822/I think thought they changed in 54 or maybe it was 55. | | | | | Joined: Oct 2013 Posts: 15 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 15 | thanks but original pic please | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | A couple of years ago I found an un-restored, original paint and upholstery '49 GMC 1/2 ton for sale on eBay with only 2700 original miles on it. It was in such good condition I wanted to take some photos of it to help me with the restoration of my '52 GMC. As you probably know, arm rests were sold as accessories and there is no way to tell for certain that the arm rest is original to the truck, but judging from everything else it is likely. The owner eventually sold the truck for $32K. drivers side door | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....probably the biggest difference is the original's were metal base and the new ones plastic?? | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Unfortunately I didn't pay that much attention to the base to see if it was metal or plastic and I can't tell from the picture what the material was. The vinyl fabric appears to have a more pronounced pattern on the reproduction but the stitching looks very much like the one on the '49. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Brad, I don't believe those arm rests are from the '47-'54 trucks. They look like they're from a car. The part number from the Master Parts Catalog, 1929-1949, is 986154. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I think you are correct, Tom. I think the car had the shiny metal band in the arm-rest and the truck did not?
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | MT's temperament can be difficult to deal with but say what you want, the guy is a wealth of good info and pictures. Click here | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | It was to show manner of construction metal vs. plastic should have added that. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Brad,
Would the car arm-rest bolt up to the truck door?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A quote from Greg's link to the Classic Parts blog answers that Tim: "The Chevy standard car arm rests pictured earlier don't adapt to the trucks very well as the mounting screws are set at a 45 degree angle which makes it hard to mount them flush to the door without having a screw protruding on the inside of the door which prevents the windows from being rolled up or down." dg
Denny G Sandwich, IL
| | | | | Joined: Oct 2013 Posts: 15 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 15 | thanks for the pics guys. had a good source send pic and said its an original but made of bakealite witch is very brittle and he thought it would break easily if installed.
Last edited by Peggy M; 04/18/2023 6:48 PM. Reason: remove image since didn't work
