3 members (baldeagle, panic, 1 invisible), 78 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#988354 11/24/2013 2:58 AM
not sure if this is the right place but i'm working on my 53 3100 and i'm looking at the vent wing where the handle goes and there is no handle or stud. just a hole. what can be done to fix this or do i need a new vent wing frame.
basham #988366 11/24/2013 3:58 AM
sounds like the stud for the wing vent handle is broken off and gone. If I remember correctly that chrome piece the stud fits to is riveted, or tack welded to the "surround" piece/frame. I think I actually have one from a rusted up vent window frame somewhere in the shop but its a little rusty where it fits down in the window frame track. Am I making any sense?
....I'm sure someone will be along later and that knows for sure. Maybe the moderator will move this to the paint and body??
Good luck.
Achipmunk #988487 11/24/2013 8:13 PM
yes the stud is missing and i'm trying to figure a way to fix without buying a new frame. any ideas.
basham #988498 11/24/2013 9:21 PM
Sir Searchalot
Sir Searchalot
You can post an ad in wanted for parts. If you have the "bracket" still on there, I think you would have to take out the glass from frame, machine a stud/modify a bolt with proper configuration and weld it on. (chrome damage) Or derivet the bracket and do the work on it and rerivet. That's if you can not find a frame or donor frame cheaply enough. The AD guys have had this problem no doubt and will know better than I. TF's are similar.
bartamos #988558 11/25/2013 1:26 AM
I was notified that what i needed was on ebay. Problem solved. You guys on here are great. Thanks.
