| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | not sure if this is the right place but i'm working on my 53 3100 and i'm looking at the vent wing where the handle goes and there is no handle or stud. just a hole. what can be done to fix this or do i need a new vent wing frame. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | sounds like the stud for the wing vent handle is broken off and gone. If I remember correctly that chrome piece the stud fits to is riveted, or tack welded to the "surround" piece/frame. I think I actually have one from a rusted up vent window frame somewhere in the shop but its a little rusty where it fits down in the window frame track. Am I making any sense?
....I'm sure someone will be along later and that knows for sure. Maybe the moderator will move this to the paint and body?? Good luck. | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | yes the stud is missing and i'm trying to figure a way to fix without buying a new frame. any ideas.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You can post an ad in wanted for parts. If you have the "bracket" still on there, I think you would have to take out the glass from frame, machine a stud/modify a bolt with proper configuration and weld it on. (chrome damage) Or derivet the bracket and do the work on it and rerivet. That's if you can not find a frame or donor frame cheaply enough. The AD guys have had this problem no doubt and will know better than I. TF's are similar.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | I was notified that what i needed was on ebay. Problem solved. You guys on here are great. Thanks. | | |
