Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (cmayna, 2-Ton, 2 invisible), 47 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#987534 11/20/2013 5:45 PM
I am thinking about swapping my 216 out and putting in a 230 .Mounts are not a problem,but what about the bellhousing,will it work?
not the same,
Tommy
59 apache 1/2t
261 short stepside
250 is next generation after your stock motor, all different. Good news is that the 230 is same bellhousing as a V8 so easy to find tranys to fit that, motor mount kits are around to fit the side 230 block mounts. Try Chassis Engineering for mounts.
1946 1/2-Ton Chevy
Thats what I thought,but was not completely sure. I have a 230 engine that has been sitting for over 30 years in the barn.I also have a bell housing for it.I am not sure about a flywheel and pressure plate,I may have that to,will have to look.I would like to do 2 carberator set up,and don't think I want to spend that much money on the 216.i don't want to use a small block v8 It seems thats what everyone does and would like to do something a little different.How does the 230 compare to a 235,is the power the same.Is one better than the other?
Look in Gallery at Joe Hand's '37 with 250 inline, sweet.
Jim
1946 1/2-Ton Chevy
Thanks for the link Jim.It is a nice truck.I also like yours as well ,and this is the look I want to go for.Very nice trucks
After talking with larry at Clifford performance,I going with the 230 engine.I will be using a 250 crank and some performance part from cliffords.
The 230 is more modern than the 235 is. Torque was more on the 230 (for some reason) at 220 lb/ft. The 235 got to 215 lb/ft. on the 1959-62 versions. 235 has 4 main bearings, 230 has 7 main bearings.
Of course the 230 is a short stroke engine vs the 235 is a long stroke engine.
