7 members (baldeagle, 78buckshot, thekid1950, Rusty Rod, cmayna, tclederman, Oswald),
47
Mod | | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I am thinking about swapping my 216 out and putting in a 230 .Mounts are not a problem,but what about the bellhousing,will it work?
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 |
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | 250 is next generation after your stock motor, all different. Good news is that the 230 is same bellhousing as a V8 so easy to find tranys to fit that, motor mount kits are around to fit the side 230 block mounts. Try Chassis Engineering for mounts. | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Thats what I thought,but was not completely sure. I have a 230 engine that has been sitting for over 30 years in the barn.I also have a bell housing for it.I am not sure about a flywheel and pressure plate,I may have that to,will have to look.I would like to do 2 carberator set up,and don't think I want to spend that much money on the 216.i don't want to use a small block v8 It seems thats what everyone does and would like to do something a little different.How does the 230 compare to a 235,is the power the same.Is one better than the other? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Look in Gallery at Joe Hand's '37 with 250 inline, sweet. Jim | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Thanks for the link Jim.It is a nice truck.I also like yours as well ,and this is the look I want to go for.Very nice trucks | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | After talking with larry at Clifford performance,I going with the 230 engine.I will be using a 250 crank and some performance part from cliffords. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | The 230 is more modern than the 235 is. Torque was more on the 230 (for some reason) at 220 lb/ft. The 235 got to 215 lb/ft. on the 1959-62 versions. 235 has 4 main bearings, 230 has 7 main bearings. Of course the 230 is a short stroke engine vs the 235 is a long stroke engine.
John | | |
