2 members (Peggy M, Simso),
291
9
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | Forgive me but I am putting the inner fenders back on my 1950 and it looks like there is a bracket that connects the inner fender to the firewall? Is this correct? Does anyone have a picture of these so I can look through my parts? I cant find a callout in my books. Thanks! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I suppose your talking about the two long "rods" that indeed attach to the inner fender, and holds the fender as well, and also bolt toward the center of the firewall. There is a metal piece on one end that bolts to the fender, and the rod/brace bolts to it.
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | The Factory Assembly Manual has the dimensions. See Sect 11 Sheet 12.00 | | | | | Joined: Oct 2010 Posts: 6 New Guy | | New Guy Joined: Oct 2010 Posts: 6 | Parking brake bracket? Driver's side only.
1955 5-Window First Series Chevy 1996 SVT Mystic Cobra 2010 Silverado LTZ Crew Cab
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | Guys thanks for the responses. I was trying to understand more on any brackets that mount the rear bottom area of the inner fenders to the firewall. The one bracket link shown looks like it could be the part but is there one for both sides? The bracket i am referring to would have 3 mounting hole locations to connect fender to firewall. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | For AD trucks: No bracket on right side (inner fender bolts directly to the toe panel). The left side bracket doubles as the parking brake pivot bracket. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As DavidF posted, on the passenger side the bottom of the inner-fender is bolted to the toe-panel - I think there are captive nuts in the toe-panel.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Captive nuts in the inner skirt on the passenger side, captive nuts in the bracket on the driver side.
DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | Thank you for the pictures. This helped alot!! | | |
