Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#978542 10/14/2013 11:13 AM
the only number that can be found upto now (vin plate is missing ) is the engine number A270791070 can anyone tell me more about my truck please
we believe it to be a 1951 gmc 450 and its a semi tractor
cheers,
,mike,
live or die do it with spanner in hand
spanners #978556 10/14/2013 1:17 PM
I don't know about your 51 but on my 56 the vin is also stamped on the top of the left frame rail over the front axle.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
HevyHauler #978585 10/14/2013 3:05 PM
the frame vin stamp did not start until 55.2 on Chevs, although apparently some early GMCs had a number stamped into the outside of the pass side frame rail front horn
spanner, wasn't there a whole thread of folks telling you about your truck from pictures you posted? th only thing the engine number tells you is that engine is a 270
spanners #978683 10/15/2013 12:55 AM
3B Offline
Hy spanners, after checking one of my Motor's manuals I think your truck might be a 1951 400-27, they were built from 1951-54. Possibly tractors did not have a fuel tank filler necks and fuel tanks in the cabs, I'm not sure. Smaller trucks did not use the 270 in those years. This is operating on the assumption that the engine has not been swapped, hope that helps.
spanners #978694 10/15/2013 1:31 AM
400 series '47-'54 trucks came standard equipment with Dayton wheels. The 270 was used in 450, & 470 trucks up until 1951. The 302 was used from '52-'55 1st series, on this body style.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanners #978741 10/15/2013 4:29 AM
In my opinion, it's a 1951 model. Only year for pull down door handles, & door vent glass. '47-'50 models have a driver side cowl vent. 1952 450, or 470 would have a 302 in it. You just need to figure out if it's a 450, or 470 series.
Spanky Hardy
1950 GMC 250 1-Ton
spanners #978743 10/15/2013 4:35 AM
To determine 450, from 470. Try to find some identification on the rear differential.
Spanky Hardy
1950 GMC 250 1-Ton
spanky #978919 10/15/2013 11:08 PM
well its definetly a two speed rear ,jim, says its air shift ?
which to me it sounds like its an eaton , the rear wheels are the same six lug as the fronts , do they look like ,dayton, rims to you ?
spanners #978951 10/16/2013 1:42 AM
Do you mean vacuum shift.
Spanky Hardy
1950 GMC 250 1-Ton
spanky #978989 10/16/2013 3:40 AM
hi, spanky, thats what i thought but my mate ,jim, who,s yard she,s at 300 miles from me,, says its air shift . and that its got air operated wipers aswell ???
spanners #979013 10/16/2013 10:54 AM
As Spanky posted, your friend might be referring to a vacuum two-speed rear selector.
Most likely it has a vacuum wiper motor, too.
It might also have a hydro-vac (vacuum) "brake booster" (depending on the year/size of the truck)?
spanners #979093 10/16/2013 7:29 PM
Does it have a air compressor on it? Are the horns on top air actuated also, or electric? Is it air brakes, air over hydraulic brakes, or hydraulic brakes? Usually a GM truck with Factory air compressor will have an air guage where your headlight switch is & the headlight switch is higher on the dash. Also the air wiper switch would be in the area just below the air guage.
Spanky Hardy
1950 GMC 250 1-Ton
spanners #979095 10/16/2013 7:43 PM
it is fitted with a compressor and they are air operated horns that work!! its piped for trailer air brakes (2 line setup) but the trucks on hydraulic brakes ,, ther are two air guages in the dash centre below the radio cut out..and a trailer brake valve on the steering coloumn .
spanners #979100 10/16/2013 8:09 PM
I've seen that air conversion setup in a Chevrolet Silver Book, & GMC Equipment Book. Very interesting. I'd like to see a photo of that air compressor setup.
Spanky Hardy
1950 GMC 250 1-Ton
spanners #979108 10/16/2013 8:39 PM
spanners #979126 10/16/2013 10:19 PM
spanners #979129 10/16/2013 10:23 PM
red58 how do you meen ,skip using the buttons,,?
all iv,e done is copy and paste ,,
spanners #979131 10/16/2013 10:31 PM
well then you've copied the wrong thing, you just want the address to link to the pics, not the tag to embed the image on the forum, copy the address from the browser address window rather than the 'easy links' PB provides on the page - you don't want those [IMG] tags, note the difference between your links that don't work and mine that do, I simply extracted the actual address from yours
spanners #979234 10/17/2013 3:08 AM
Hey Bill since the demise of Web shots I too am using photo bucket and cannot seem to get links to work could you fix my links as well?
Sorry spaners didn't mean to high jack your thread but it seems as though we are in the same boat.BTW very cool truck and I am very interested in learning more about how the trailer air brakes interface withe the trucks hydraulic brakes. I would love to be able to pull my air brake tilt top trailer with my 56 6100 dumper.
user
spanners #979241 10/17/2013 3:29 AM
I would Grant, but the one in your sig line doesn't get anywhere to start from, missing your user name and the server number at the beginning, so just gets a default photobucket entry page grin
on the right of your album or picture page is "Links to share this album" - left click the top one [Email & IM] and it should say "copied", then just right click and select paste in an address bar or a text box here
spanners #981799 10/27/2013 7:54 PM
hi,, good news the GMC came home to me today ,yipeeeee..
here she is with some ,odd,, stable mates .
http://s468.photobucket.com/user/spanners1964/media/GMC27OCT2013026_zps3f2b5ed7.jpg.html
spanners #981800 10/27/2013 7:58 PM
and theres even more good news,,, after prying open the stuck !!!! glove box door,, the ID plate that everyone else had looked for was there under about 1/4 inch of crap,,that i cleaned n, dusted of to reveal
http://s468.photobucket.com/user/spanners1964/media/GMC27OCT2013032_zps2cf2f1d0.jpg.html
http://s468.photobucket.com/user/spanners1964/media/GMC27OCT2013031_zpsf3c4fc6f.jpg.html
spanners #981802 10/27/2013 8:00 PM
the links above also lead to other photos ,,
spanners #981807 10/27/2013 8:32 PM
O.K., It's official. 1951 450 series. So says the "GMC Parts Identification" Tag. Good job. Nice truck ! What are your plans for it ?
Spanky Hardy
1950 GMC 250 1-Ton
spanky #981830 10/27/2013 10:32 PM
plans at the moment ,, look like work my way through it doing the necercery jobs to get her roadworthy then run her awhile to check everything out ,, then strip clean n, paint and find a stepframe trailer to carry other trucks and vintage tractors etc .
spanners #981898 10/28/2013 2:38 AM
Sounds like a good plan. Can't wait to see a trailer hooked up to it.
Spanky Hardy
1950 GMC 250 1-Ton
spanners #981905 10/28/2013 2:56 AM
Hi All,
I have 3 GMC 450s all have Motor Wheel 6 lug rims with compression washers. This was standard from the Alameda Plant.
There were three factory options from for brakes, Vacuum over Hydraulic, Air/Pack over Hydraulic and straight air brakes.
Also for 52 and 53, besides the 302 CID there was a General Motors Diesel 3-71 option w/Air brakes.
I am also negotiating to buy a '53 450-30 Fuel Tanker and a '52 470-30 tow truck with Holmes Wrecker.
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
spanners #981914 10/28/2013 3:08 AM
Outstanding find, I am jealous...I've been looking for a tractor for ages.
Have fun and enjoy your find.
spanners #981919 10/28/2013 3:13 AM
This is a neat looking old truck. This is what I have in mind for my 6100. What is the wheelbase measurement on that truck?
1950 4100 - unrestored and driven weekly for almost no reason at all.
spanners #981925 10/28/2013 3:44 AM
Hey GMCPic, Did you ever get me a picture of that 470, with the Holmes Wrecker on it. Which model Holmes is on it. A 515, 525, W35, or W45 ? Save as many "400" series trucks as you can. They're my favorites.
Spanky Hardy
1950 GMC 250 1-Ton
GMCPic #981937 10/28/2013 4:16 AM
i had a dealer / exporter from california contact me via the internet earlier and fill me in on a bit of the trucks history .
it was saved just days before it was to be scrapped/crushed and was one family owned from new ==jewett or jc,wett farms from WILLOW near SACREMENTO and not from BUSH COLERADO like i was first informed .. he said he will find out more and get back to me,,, i hope he doe,s .. but not holding out to much hope as he said it came from a deceased estate that was sold up ..
