4 members (dt235sd, Wally / Montana, carbking, homer52), 146 guests, and 1 robot.
Topics128,195
Posts1,057,369
Members48,469
It took me 5 weeks to close the deal, but I finally got one of the compressors I had my eye on. It will stay outside under a custom doghouse style enclosure. It needs a new muffler, air hose, water separator and a regulator to reduce pressure from 175 psi to something lower and usable. Suggestions?
http://i1278.photobucket.com/albums...ir%20compressor/102_4649_zps1268cb2f.jpg
Jay, if you ever intend to do any painting be sure you set it up so as you get DRY air. Even though I've not had any problems in almost 10 years, and I do no painting I wish I had did a better job on set up.
That sucker should give you all the air you need smile
With the exception of filling tires everything you use compressed air for wants to and clean and dry.
An after cooler between the tank and the pump will do wonders for getting it dry.
Compressors are like politicians they make a lot of hot air.
Got to cool it to get it dry.
For regulator trap and filter good old ebay look for either 1/2 in or 3/4 in.
Need the filter to remove the oil.
I have never seen an after cooler. I'll research it. Any hints what kind or size I would need?
It's a high pressure radiator essentially.
People have used ac condensers.
It's an option on some of the better compressors.
Much like a chiller except it's between the tank and the pump instead of after the tank.
I use a Pneumatech refrigerant dryer that I got off ebay....works very well. I ran the air right off the compressor head into it and then in the tank, so moisture removed before it hits the tank:
Pneumatech dryer
Refrigerated air dryers are the best of all methods to get dry air. Downside is they take more power to run.
Compressed air often has 1/2 the input power to the motor in it and it is hot. IF you run a water cooled after cooler you can extract much of this heat and use it to heat shop incoming cold water or, or.
IF you really must have near absolute dry air then the refer unit would be able to do it at much smaller size and power consumption.
Dan Bentler
Moderated by  MNSmith
