8 members (32Fordpuchoptop, 3B, TUTS 59, Shardean, msmall, carbking, Bill Hanlon, FrankenChevy),
56
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Somebody pulled up next to me on the highway today and said my front right tire was bouncing up and down. I did notice a lot of shaking while driving at higher speeds. Is this caused by an unbalanced tire or what? | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | It could be that. Also if your front shocks are shot it could cause the tire to bounce and eventually wear it out of round. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Typically. Go have it balanced. If you still have a bounce or shake after that, it will be time to look at the suspension components.
Actually, even before you have it balanced, raise your vehicle and spin the tire. Look to see if the tire is separating. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | What do you mean Separated? Like about to fall apart or showing the tire wire mesh? | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Radial or bias-ply tire? Broken belt if its a radial perthaps. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Separated means that the tread is separating from the tire. It isn't always visible, but can show up when the tire is spinning.
You could have a bad tire, or it may be out of balance. You could even have an out of balance brake drum. Check the tire first and go from there. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Check the shock first - bounce the front end, if it does not "settle" in one or two up-down movements, replace (on a 1954) the shock.
Then, have the tire inspected, and, if the tire is good, have it balanced.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | When you balance it spend the bit extra to have it "road force" balanced. That will tell you a lot.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Had the front two tires replaced because they were showing wires and dry rotted. The truck rides smooth as glass on the highway now.  thank y'all! | | |
