1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#976209 10/03/2013 8:48 AM
Somebody pulled up next to me on the highway today and said my front right tire was bouncing up and down. I did notice a lot of shaking while driving at higher speeds. Is this caused by an unbalanced tire or what?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
It could be that. Also if your front shocks are shot it could cause the tire to bounce and eventually wear it out of round.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Typically. Go have it balanced. If you still have a bounce or shake after that, it will be time to look at the suspension components.
Actually, even before you have it balanced, raise your vehicle and spin the tire. Look to see if the tire is separating.
What do you mean Separated? Like about to fall apart or showing the tire wire mesh?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
Radial or bias-ply tire? Broken belt if its a radial perthaps.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
FPMnky #976237 10/03/2013 10:29 AM
Separated means that the tread is separating from the tire. It isn't always visible, but can show up when the tire is spinning.
You could have a bad tire, or it may be out of balance. You could even have an out of balance brake drum. Check the tire first and go from there.
My 46 GMC on Photobucket
FPMnky #976246 10/03/2013 10:57 AM
Check the shock first - bounce the front end, if it does not "settle" in one or two up-down movements, replace (on a 1954) the shock.
Then, have the tire inspected, and, if the tire is good, have it balanced.
FPMnky #976271 10/03/2013 12:45 PM
Ex Hall Monitor
Ex Hall Monitor
When you balance it spend the bit extra to have it "road force" balanced. That will tell you a lot.
Had the front two tires replaced because they were showing wires and dry rotted. The truck rides smooth as glass on the highway now. grin thank y'all!
DJ __|__
--O-(_)-O--
'54 Chevy 3100
