4 members (38Kiwi, UtahYork, dt235sd, Hotrod Lincoln), 123 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,471
V
V Offline
I'm considering shortening up my Big Bolt and putting on a Factory Long Box, possibly with flares or stepside fenders narrowed up on the fleetside box...I know it may not be the most usefull truck....It's just a thought at the moment, and I know it's been done before...mine's a 63 GMC 960...
I want to do the same on my Flatbed 59 2 ton.
Check this page, it's a -46 but the idea is the same smile
http://www.oldchevytrucks.com/Showcase/Dually.php
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
I really like the idea. But I would cut the box and add on to it to make it fit. Not cut the frame.
I had saved a pic of a 60-66 c-60 with a pickup box. It was orange but no I can not seem to find the pic. it had modifed stepside fenders as dually fenders. Not as modified as the fenders I did on big bertha though.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
V
V Offline
I don't plan on cutting the frame to shorten mine, I'm going to remove the bolts/rivets for the rear shackles (and crossmembers) and move them forward 48 inches (my wheelbase is 175 inches, regular longbox pickup is 127 for 1960-66), then drill/rebolt, and deal with the driveshafts/brakelines, and cut off the excess frame past the box...
Check-out "Youtube" "Goliath in the BACK YARD" '65,or '66 C-60,with a fleetside box,and fender extensions. Truck has "Budds",but runs singles in the rear,mounted with the dish to the inside,giving it a slightly wider stance than mounting them like the inside "duals". Hope this helps.
Mo' Tater
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Hi,Rich's Toys!Thanks for the up-date!! looks WAY BETTER with the new tires,and the BIG-DUALLY look!!
Mo' Tater
About a week ago I acquired a 1949 Chevy 1 1/2 ton 4400 series. A very long time ago somebody shortened the frame and moved the axle forward to put the step side bed on her. I think it looks pretty cool myself. I can't wait to get started on it. Now I need to find the other two matching wheels for the rear end so she'll be a dually again. Space the fenders out a little with stock size tires and I think it will look very unique and be more user friendly without all of the extra length. Now she looks like she could run down a railroad track...
Will post pics when I can figure out how to do it...
Toolman
1949 Chevy 4400 1 1/2 Ton Pickup
