5 members (TrknGMC, Stewart2, Otto Skorzeny, ndkid275, 55shaker), 124 guests, and 2 robots.
Topics128,165
Posts1,057,011
Members48,458
Just thought it would be a good idea to see what other bolters are doing to their engines. I need to do some touch up on mine, but here's a picture and short video...
engine pic
engine video
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Sixes only?
Hey Mark, you can't leave me out.... smile
Better post it before the rules change
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0166.jpg
Don't laugh at the wooden dowel which was where to locate the hole for the throttle cable!!
Here's my 1961 261 9 years ago. It doesn't look nearly that clean now.
My 1961 261 in 2004.
well, it's not a 'stovebolt', and not even going into a Stovebolt, but it is GM, and it is mine, and it's a video of the first fire up, which is always fun grin
Wally,
Nice looking 261 engine.
What carburetor?
Do you like it?
Is the inlet fuel filter the only fuel filter?
Nice gas/vacuum plumbing.
Where did you connect to the vacuum wiper (on the far/hidden side of the carburetor)?
Here's my '54. I've posted them before.
> Prepped for painting Wasn't gonna give my fuel filter a chance to leak, so I left it on and bought a lot of blue tape.
> Drivers Side Since the pic was made, I replaced the Echlin VR cover with a Delco Remy; rotated the cowl vent drain hose 45deg toward the drivers side. Recently learned that the oil pressure and temp tube should exit the firewall with the speedo cable.
> Passenger Side I've replace the gear-type hose clamps with earlier type. Couldn't get the wire pinch clamps shown in the FAM to secure the hoses.
> Video - Filter and Pump
EDIT:
"sstock" - Sometimes Photobucket videos don't load on an iPhone. You may be able to find it in my "Carburetor" album, then choose view full web site. I dunno.
> Carburetor Album
Hey Bill - The Buick straight-eight in your Photobucket album is my favorite!
- Lonnie
Last edited by LonnieC; 05/19/2013 10:49 AM. Reason: Photobucket video problem on iPhone
- Lonnie
My '54 3104
Thanks David for starting this thread, I love looking at other peoples bolts. Here is mine, I just got the truck a couple months ago, got a lot of work to do but did fix some engine mechanicals to get he purring like a kitten. Had 2 really bad intake valve guides but replaced them all because they had been previously knurled. All the springs were shot with seat pressures all over the map. I exhaust valve needed replacing-then a three angle grind. Carb kit, set the point dwell, idle mixture for best vacuum and initial timing and here it is:
Thanks, Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Lonnie, great looking engine, lots of hard work there. The video link was broken though.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
posted before, but here is my 302 jimmy
pics in this jc article
http://www.oldchevytrucks.com/blog/index.php/category/high-performance/
video on youtube
Tim,
The carb is a Rochester Monojet. It's not Carb King's favorite but it's worked well enough for me that my Carter YF 2100S has waited for years on the shelf. (No, I won't sell it.)
I have a second in-line fuel filter on the other side of the motor. That's the one I change routinely. I could buy a Fram filter that screwed into the carb in 2004 but I haven't checked lately. Maybe I should!
I now have an electric wiper motor but the manifold vacuum was a "fore pump" for the fuel pump vacuum port. Here's a diagram of how it was set up.
Diagram for Vacuum Wipers.
Here's Ol' Darrell's engine. Just got it running like a clock the other night, but I'm fighting sticking intake valves again. Ugh!
Darrell's engine
Here's the engine in my 1969 3/4T panel.
http://s1109.photobucket.com/user/R.../Driverssideview.jpg.html?sort=6&o=1
It has a 4 row bb radiator and a 350 fan shroud and fan. I added power steering and a 94A alternator. Also added an HEI and 10.6mm wires that were to short for a 350. Next on the agenda for the engine compartment is a new master/booster combo for power brakes and a replumb of the fuel and vacuum lines.
best wishes,
Les
oh, if I must show it
just joking, not mine...lol
Redryder pix
My Hotrod
Everyone has such nice pictures and videos. Inspiring..
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
Hey Joker, when ya gonna DO sompin' with dat engine? wink
Built by Troy Robertson, Old Inline Power Company, Charlotte NC
Isky E2 cam
Crank 20/20
Milled .060 Head
Bored .040
Webber carbs
Offenhouser intake and valve cover
William Headers
Magna Flo Mufflers
here is mine before i got it started.. car is still in the process of being built..slow but sure
http://s202.photobucket.com/user/rcplumley/media/51%20chevy%20project/IMG_8675.jpg.html
if you cant run with the big dogs...then stay on the porch
http://s202.photobucket.com/user/rcplumley/library/
Red dot, center of chest ...
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Here's mine starting up for the first time since 1995
Not done yet but getting there.
1954 261
Bruce
My Trucks
Stuff I Collect
Not an inline, but I believe 283's were an option in '59
Gas Pumper
Gas Pumper
Very cool stuff guys! Keep up the good work! If you ever get a desire to remove the road tube, you can install a PCV system per my instruction on the web site. I have tested it and it works really great.
Suggest (but not totally needed) a fuel pump with the vacuum feature so you are only plumbing a few inches. I have mine ran clear to the intake.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
1938 Chevy 1/2 ton Pickup
1940 Chevy 3/4 KD Pickup
1946 Chevy 3/4 ton pickup
1940 Chevy 1/2 KC Pickup
1939 Chevy 1.5 Truck
Here's a 3-53T Detroit to go in my 1 ton pickup.
•1952 Chevrolet 3800 pickup
---All pictures---
1954 3100 - decided that the medium gray was the best color for me.
https://myengine.shutterfly.com/pictures#n_5
