2 members (Sjm, Tyler Watts),
112
Mod | | | Forums66 Topics128,281 Posts1,058,464 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I got started on the passenger side floor pan and kick panel sheet metal.I have two guys mentoring me on this project and they actually cut out my sheet metal and told me to watch.This guys name is Gary,and he is really a treasure to have around. ready to cut outTony mapping out where to cut the rusty kick panel . where to cut Gary cutting the rusted section of kick panel. cutting kick panel The other guy is Tony,some of you know him for his reputation with 1960-1966 Chevrolet trucks.He smiled the whole time they were taking my floor apart,even though it was an AD suburban. Tony thinking AD trucks The rusted part of floor cut out and kick panel. cut out Part of the inner cowl had some rust through,I cut it out. inner cowl Cut out and using it as a template.I bought some 16ga sheet metal and made my own all by myself. piece cut out Traced part onto new metal. traced Cut out new part with a die grinding wheel. new part Hammered the ribs into the part. hammered ribs old part and new part side by side. new and old part Tack welded into place. tack welded After grinding and re-spot welding pin holes. welds ground off Tony showed me how to cut and form the floor board sheet metal. new metal We por 15 areas that wasn't accessible after welding in metal. por 15 Tony showed me how to spot weld the floor metal in place. floor welded in I have to finish up the kick panel and toe board area and proceed to the drivers side floor pan and kick panel. I want to thank my two mentors on this project,I really appreciate it. Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Tim, I know your getting excited. Each piece is one piece closer to being finished. Say hi to Tony for me. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Tim:
You are an excellent protege! I will take a person with passion, over a fellow with a load of talent, but no "want-to", anyday. Great work. The rib-method is ingenious and a good way to get the results you need/want, without the bank-account-busting metal forming tools.
Two thumbs up and an A+ from me.
Alvin, thanks for the shout-out. I hope you are doing well.
P.S. - Gary is a wealth of knowledge on this stuff and I appreciate his help and enthusiasm when he helps me, as well!
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Did you do all that grinding and welding with the battery in there? I had a battery blow up on me once and the first thing I do is get it far away from any potential sparks and hot stuff.
Excellent job on the metal work guys! | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Thanks guys,the rain has me at a stand still,will get back on it this weekend.
Friedtmater,we did do all the work with the battery in tact.I never even thought of removing it.Thanks for the safety tip.
| | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Bowtietim: Hey this is real good!! Keep the story and pictures coming!! Thanks Ter | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Hey Tim. Where are the updated photos?
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The next item to attend to was the kick panel,so I marked out what I needed. kick panel Cut to shape and trial fitted it.I realized the horizontal beads didn't line up with my originals,and yes this is a made in the USA reproduction part.I had to cut out 7/16" and weld back together to get the beads to line up. kick panel shortened Drilled the holes for my spot welds or plug welds.I looked at the assembly manual to get an idea whee they should be. spot weld holes drilled Kick panel welded in and I had to have Tony help me with the corner of the toe board. kick panel and corner toe board Yes,my suburban has been violated.Tony just had to use a piece of 1964-1966 sheet metal for the corner of the toe board. Cut the toe board to fit what I needed.We realized the after market beads are wrong on the toe board as well.I had to extend the vertical bead like the original. toe board modification Tacked the bead back into position. extended bead to drop down further Toe board piece tacked into place. toe board tacked into place Tony fitting the corner toe board piece. tony My suburban feeling fortunate to be welcome at Tonys shop. My burb at Tonys Tony,thanks again for helping me when I got stuck.I really appreciate your help. Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | You guys are doing great work......
I love seeing progress pics and the stories that go along with them.
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | How about some updates. The work you did looks great. I hope it is progressing well. You will be ready for driver side now! Good job.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Tony,Ive been shut down for a week and will probably be a week or two longer before I'm able to get back to it.I still have some welding on the passenger side before I start the drivers side.
Thanks!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | Wow! Nice work. Same stuff I have to do to my Burb and I'm not looking forward to it. I'm figuring on getting it running first. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thanks Tim for a great write up and descriptive pictures.  | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | LOTS of NICE WORK. Do you happen to have good pictures of the pass side floor where the jumper seat mounts up from what i could see your floor there looks to be OG | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Tony,I took some pictures for you this morning.The sheet metal that is tack welded under the jump seat is factory. jump seat bolted in place floor pan under jump seat floor pan under jump seat #2Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Tim THANK YOU those pics are perfect and exactly what i needed to see | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I need this portion of my floor is it made i didnt see it on jim carters site unless im blind which i could be LOL pic sure borrowed from bowtietim FLOOR SECTION I NEED UNDER JUMPER SEAT FOR MY 49 SUBURBAN
| | | | | Joined: Jun 2001 Posts: 794 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 794 | I could not find that section either bigtony55, and had a tech hand make mine. The section only took him about 3 hours to make and I plan on putting a floor mat over it so no one will ever really know that it is not 100% correct like factory.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I could not find that section either bigtony55, and had a tech hand make mine. The section only took him about 3 hours to make and I plan on putting a floor mat over it so no one will ever really know that it is not 100% correct like factory. There enough people out there parting old suburbans out hopefully i can find one willing to sell me that part of the floor LOL | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I could not find that section either bigtony55, and had a tech hand make mine. The section only took him about 3 hours to make and I plan on putting a floor mat over it so no one will ever really know that it is not 100% correct like factory. There enough people out there parting old suburbans out hopefully i can find one willing to sell me that part of the floor LOL If they removed it, it would have been bad too. Unless it came from a show truck, they are all bad. All you need is a flat metal plate, the brackets for the seat and two pins used for the mat and you won't be able to tell the difference. The floor is the same used on the truck, one difference is the truck has a full width seat riser and the suburban has a seat riser under the drivers side only. They use the jump seat to get into the back so they created the plate to cover the dip that is present under the jump seat. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I could not find that section either bigtony55, and had a tech hand make mine. The section only took him about 3 hours to make and I plan on putting a floor mat over it so no one will ever really know that it is not 100% correct like factory. There enough people out there parting old suburbans out hopefully i can find one willing to sell me that part of the floor LOL If they removed it, it would have been bad too. Unless it came from a show truck, they are all bad. All you need is a flat metal plate, the brackets for the seat and two pins used for the mat and you won't be able to tell the difference. The floor is the same used on the truck, one difference is the truck has a full width seat riser and the suburban has a seat riser under the drivers side only. They use the jump seat to get into the back so they created the plate to cover the dip that is present under the jump seat. So the truck floor IS the same in that are i looked at a parts truck i have real quick today to see that section and i thought HMMM it looks similar except the full length seat riser as you mentioned im going to have to look at it better and see if i can salvage that area out of it for my suburban thanks for the info | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Tony, we are hijacking this thread, let's start another one or pm me. | | | | | Joined: Mar 2013 Posts: 4 New Guy | | New Guy Joined: Mar 2013 Posts: 4 | Your pictures have helped me alot | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If you're talking about my pictures,it's why I took the time to take them and show my process.Glad to hear it helped somebody.
| | | | | Joined: Oct 2012 Posts: 28 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 28 | Incredible detail, thank you for documenting this. Has anyone done a full pan documention ?
52 suburban 48 Palace
| | | | | Joined: Aug 2013 Posts: 3 New Guy | | New Guy Joined: Aug 2013 Posts: 3 | He Chipmunk,
How is your panel coming along, is it on the road yet?
Sam | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Yep, the panel is at least "on the road". I'll have to drive it down to your place one day. I may want one of those AD's pickups you have...if they're cheap enough!! | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Hey Alvin. See you at All Truck? | | |
