6 members (UtahYork, 2-Ton, 68ironhead, Stovebolt48, 50Chevy3100, 1 invisible), 71 guests, and 3 robots.
Topics128,187
Posts1,057,212
Members48,465
Page 97 of 177 1 2 … 95 96 97 98 99 … 176 177
I managed too put some scratches across the roof while backing into my yard too load up some old wooden fencing too haul away. not serious but ironic, it is the exact same place and tree that bent the drivers door when a limb caught the top of the door and bent it forward toward the front fender twenty seven years ago.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
got the engine running finally !!!!!!!!!!!!!!!! it's been a long hard journey but it now works grin grin grin now to the brakes.................
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Painted the parts I cleaned yesterday including the inside of the hood and parts to go with it, dome lamp assembled and wire ran, gas tank back in new wiring ran to sending unit. License plate and tale lamp brackets back on.
Made a battery holder plate. Made an under seat hole cover so I can mount my computer and fuses.
Removed the headlight buckets and found them to be in remarkably good shape. Will paint tonight. Ordered the seals and screws from classic.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Ron, don't you know, trees don't forget!
~Jim
Little work got done today due to various appointments, but I got the door panels off, and the headliners dropped (HUGE mouse nest up there)
Still finessing the metal plate to hold the computer under my seat. Need to drill perimeter holes and paint. Made aluminum brackets for the computer to mount to the plate. Need to make a battery mount.
put new decals on my gauges and speedometer needle.
Wiring harness wired in the dash brake switch and dimmer switch back in, new seat installed, speedometer cable cleaned up and lubed.
took the truck for a short test drive about 4 miles but it over heated pretty bad got to 135. i dont have a thermostat in it yet maybe when i put one in it wont over heat.
Got the 37 out and waxed it.
went out and cranked the truck just to here it run.
Started installing a set of Altman Ez-Latches, so far it's going very well. Still have to come up with a fix for the lock feature. They don't lock with the interior handle and I'll need to find another way to do it. I'll probably get the electric remote kit but will have to look for a way for the manual interior lock.
Y
Y Offline
Sold my 53 3100 yesterday, owned it for 10 years. Spent first 5 years fixing it up, went to a few car shows and cruz'd a little. Most of the time it sat in the carport while I wrenched on my 51 & 53 burbs. I'm going to miss it, I did get a lot of enjoyment out of it, but now I don't have any excuse for not getting the burbs on the road! Plus now I need something to haul with! The new owner spotted my truck while I was cruzing and stopped to see if I would sell it, I gave him a price and he jumped all over it. He lives close by so I'll probably see it on down the road.
GET THEM BURBS DONE!!
As some of you know, I recently bought a lot of NOS parts. There was a drivers door latch in the lot and I saved it back for the burb.
I have had trouble with the latch for quite a while so last night at the car show I decided today was the day to change it.
Easy job, right? Just pull the handles, the arm rest, the door panel, 3 screws and it's out of there. Wrong.
I had to pull the window out. And of course to do that I had to pull the wing out too. And to get it out I had to remove the lower access panel. The bottom bolt didn't want to budge and the lower mount nut bracket on it pulled out of the rivets.
I changed out the latch then went to work on the vent assembly. I drilled the old rivets out of the bracket and attached it with screws. I ran a tap through the nut plate and applied Never-Seez to it and the bolt. The 'while I'm in there syndrome' hit and pulled the nut off the vent tensioner and ran a tap through it too. I brushed the threads of the stud and put it all back together with anti seize. Now maybe it will stay open on the highway.
And now the door latches when I shut it.
I got the rear hub assembly and axle out of the passenger side of my 36 1 1/2 ton, never done anything like that before. Trying to get the rear brakes completed this week so maybe I can go for an actual drive down a road rather than putting around with no brakes in the back of my farm.
I think it's more fun to be able to stop for some reason, call me crazy.
finished putting the interior in and mounted the headlight buckets that i cleaned and painted.
Just mounted my new white wall tires,on the white rims
on the good humor truck.I was glad the 2 3/4 ww was
the right size for my truck.
Straightened the grill surround, straightened the front bumper, and got the donor front RH fender hung after fixing the rust and priming. I finally got the damage done by my daughter fixed. drive
Got the new headlights in, passenger side top clip gave me a fit, driver side went straight on no issues!
Made the battery mount. Actually, modified the original battery mount to fit a larger battery. I'll probably post pictures in the DITY Forum later. Gathered some fittings to install the oil pressure sender and oil pressure switch.
My friend Mark and I got the drivers side cab weather stripping and door on last night. It's so close, I can feel it. I just have a few more wiring issues to work out then it'll be on the road (I hope).
http://www.flickr.com/photos/ajporsche/9305866274/in/set-72157632234070092
When I think back to December when I got the truck and I look at the photos I took of it then, I realize how much hard work we've put into this. It's an amazing transformation.
http://www.flickr.com/photos/ajporsche/8268190236/in/set-72157632234070092
~Dave
Wow Dave...that's some comparison. I think my weather stripping on the doors was installed wrong by the PO and that's why they don't seem to fit well. Jerry Kassis of Dr. J's Resto told me that when I met him in Sac a few months back. What a guy ! and he does great work up there in Oregon. Anyway, he is making a video on just how to install this stuff. I'll post a link when I get it.
Great work Dave wink
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Thanks Mark! It looks like we're close, I hope we run into each other some day. I love your story in the Stovebolt gallery, and Walter is a Peach!!
I'm going to try to have my truck ready for driving by September for the Roman Angels show in Grass Valley. Maybe we'll meet there!
cheers!
~Dave
Dave,
I had thought about entering mine and maybe will but it's not really in show condition...still would be fun. I need to get that spot light back on though..
PM me your phone number and/or address...I'd like to come see you and your truck...
Mark
1949 Chevy 1/2-Ton
Lucielle
Finally picked up my split stock manifold from the welder's shop! Not as pretty as I wanted but nothing a little grinding and coating won't hide.
http://farm8.staticflickr.com/7446/9312734540_d2fe144ba4_c.jpg
Got my dual master cylinder and lines for the disc conversion. Took today off to start preping the calipers and MC for powder. cool
Also picked up this little guy...
http://farm4.staticflickr.com/3817/9315673782_e38f995435_c.jpg
had to buy new radiator today champion 2 row supposed to cool 450 hp.
Socket Breaker
Socket Breaker
Adjusted the stop light switch, again... brake lights were coming on at random or staying on after I parked it. I added a washer in there for a spacer so that the nut would snug up better.
What a contortionist act that was...
-W
Did a lot of little 5 minute jobs. Got the oil pressure switch and sender installed. Made battery cables.
worked on my wiring and mounting of tail lights
....john, you mean 235?? heck, 135 is just getting going good smile
Started the truck first time. Last time she was tagged was 1954.
Thanks stovebolt guys for advice
1938 Chevy 1/2 ton Pickup
1940 Chevy 3/4 KD Pickup
1946 Chevy 3/4 ton pickup
1940 Chevy 1/2 KC Pickup
1939 Chevy 1.5 Truck
I'm actually running out of things to do at the moment 'til I can rustle up some more $$$,but finally managed to get the speedo calibrated.
I was mis-reading the instructions and failing to follow the sequence...... blush
More pix on Flickr.
Cranked it up just to hear it run. Then discovered why my fenders didn't fit very well.
Detroit at work
I also picked up a 5"X5"X1/2" steel plate to attach to my left rear spring to balance the ride. One of the guys at Garland steel had a 51 Olds with the Rocket V8. It was a great job of restoration. He gave me a link showing how the engine was built at the Lansing plant. Rocket
~Jim
Got the exhaust hung and finalized. More wiring.
Prewired some gauges. Mostly rebuilt the light sockets, put a hot lead on the gas gauge. Then did some temporary aftermarket oil pressure and water temp gauges. Tomorrow, drill some holes to hide some wires.
