2 members (baldeagle, CuzzFuzz),
27
0
Mod | | | Forums66 Topics128,003 Posts1,055,245 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 30 | Well my floor stomp starter in my 1953 1/2 ton has finally decided to call it a day, I have already converted to 12v and just purchased a 12v starter with attached solenoid. I'm not exactly sure how to wire this, does anyone have a wiring diagram for this application? I appreciate the help.
KB
Kent 1953 1/2 ton Chevrolet
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Kent Byrne, before we talk wiring, were you using a six volt stomp starter and running it on twelve volts? Flywheels for six volt have a different gear count and pitch than flywheels for twelve volt applications, the starter drive teeth are not interchangeable between starters, or between flywheels. A six volt starter must be used with a six volt flywheel and a twelve volt starter must be used with a twelve volt flywheel. You could swap in another six volt stomp starter, if that is what you had before. There are six volt solenoid type starters, but I don't think the solenoids electrical components would last very long running on twelve. just a heads up, hope that helps. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I had my 6V starter converted to a 12V by a local independent shop for $50. Well worth it. And you get to keep the button in the floor. | | | | | Joined: Jul 2009 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 30 | Thank you I appreciate the detailed info. I hadn't even thought of that. I guess I'll have to return this one and look for an older one.
Thanks again. Kent
| | | | | Joined: Jul 2009 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 30 | Good idea, I'll check around to see if anyone may do that around here. Thx I had my 6V starter converted to a 12V by a local independent shop for $50. Well worth it. And you get to keep the button in the floor.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You may want to check NAPA they sell this starter over the counter for less than $100 with a warranty. I run one in my 12-volt converted 50' and it has been problem free for two years. | | | | | Joined: Jul 2009 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 30 | Brad, did you have any problems with the starter gear and flywheel meshing?
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | No issues because it is a 6-volt starter to 6-volt flywheel. The 6-volt starter works great in this application. The part number for NAPA is 2449651 it is $80 I could not get anyone to rebuild one for that price. Comes with test specs and a good warranty. Mine works every time and still uses the stomp starter, even comes with a ss band on it. Save yourself some money over the one you have listed, with shipping (heavy) you will pay double! NAPA ships to outlets for free. | | | | | Joined: Jul 2009 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 30 | Thanks Brad, I'll check with Napa to see if its available. Appreciate all the help on this..
