4 members (TexasJim50, 3B, Otto Skorzeny, 1 invisible), 66 guests, and 8 robots.
Topics128,013
Posts1,055,322
Members48,419
#952825 06/26/2013 7:15 PM
Well my floor stomp starter in my 1953 1/2 ton has finally decided to call it a day, I have already converted to 12v and just purchased a 12v starter with attached solenoid. I'm not exactly sure how to wire this, does anyone have a wiring diagram for this application? I appreciate the help.
KB
Kent
1953 1/2 ton Chevrolet
3B Online: Content
3 Online: Content
Hy Kent Byrne, before we talk wiring, were you using a six volt stomp starter and running it on twelve volts? Flywheels for six volt have a different gear count and pitch than flywheels for twelve volt applications, the starter drive teeth are not interchangeable between starters, or between flywheels. A six volt starter must be used with a six volt flywheel and a twelve volt starter must be used with a twelve volt flywheel. You could swap in another six volt stomp starter, if that is what you had before. There are six volt solenoid type starters, but I don't think the solenoids electrical components would last very long running on twelve. just a heads up, hope that helps.
I had my 6V starter converted to a 12V by a local independent shop for $50. Well worth it. And you get to keep the button in the floor.
3B #952956 06/27/2013 9:56 AM
Thank you I appreciate the detailed info. I hadn't even thought of that. I guess I'll have to return this one and look for an older one.
Thanks again.
Kent
Kent
Cletis #952957 06/27/2013 9:57 AM
Good idea, I'll check around to see if anyone may do that around here. Thx
Kent
Kent Byrne #952980 06/27/2013 11:01 AM
You may want to check NAPA they sell this starter over the counter for less than $100 with a warranty. I run one in my 12-volt converted 50' and it has been problem free for two years.
Kent Byrne #952983 06/27/2013 11:08 AM
Brad, did you have any problems with the starter gear and flywheel meshing?
Kent
Kent Byrne #952985 06/27/2013 11:11 AM
Btw if anyone is looking at this and in the same position I was able to find one that is refurbished, its a 6v however I haven't had any problems with 6v on my 12v system. http://www.classicparts.com/1947-54-Starter-6-volt/productinfo/53-941/#.UcxVx-Xn_IU
Kent
Kent Byrne #952996 06/27/2013 11:55 AM
No issues because it is a 6-volt starter to 6-volt flywheel. The 6-volt starter works great in this application. The part number for NAPA is 2449651 it is $80 I could not get anyone to rebuild one for that price. Comes with test specs and a good warranty. Mine works every time and still uses the stomp starter, even comes with a ss band on it. Save yourself some money over the one you have listed, with shipping (heavy) you will pay double! NAPA ships to outlets for free.
Kent Byrne #953005 06/27/2013 12:44 PM
Thanks Brad, I'll check with Napa to see if its available. Appreciate all the help on this..
Kent
