7 members (Shade Baby, Pete1946, frogfarmer, baldeagle, 1955 1 Series, Jon G, 1 invisible), 97 guests, and 8 robots.
Topics128,106
Posts1,056,213
Members48,436
Waiting to receive my 55 COE cab. I bought it on ebay out of Indiana. My plan is to mount the cab on an S10 chassis and drive train. Does anyone have info on converting to air brakes? Are there conversion kits available?
1955 GMC COE 2 ton pickup Model 320 cab on S10 chassis
If you are going to use an S10 drive train, I don't see any way installing air brakes. Why do you want air brakes in the first place?
I wouldnt put it on anything smaller than a 1 ton. COE's are big and wide,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I forgot about the air brakes; it was a knee jerk reaction. I have the cab; disassembled, repaired the worse rot and sand blasted. I'm in the process of primeing and body work.
Still working on the 55 COE. I designed and installed 3 or 4 steering set ups and have finally come to a workable and safe design from a 72 Astro van. I still have 3 U joints and a stabilizer brace but it is finally solid and doesn't bind.
Moving on to front bumper, hood, front fenders and inner fenders.
Slow progress but interesting. I'm hoping to be ready for paint by fall.
Welcome,edpent! There's a truck on "youtube",that i think you'd like to see. it's a "bagged" '51 Chevy C.O.E.,and he used a '72 Chevy C-20 frame. the owner's name is: Diedelson,and I think he's from the Netherlands. I asked him some questions,(under his suscription page),and he's quick to answer. Is your truck a 1st,or a 2nd-series? That may surely make a difference,as far as cab-mounts,and more than likely,other components as well. Good luck,and congrats on your steering solution!
Mo' Tater
My 55 COE is first series. Still designing and frabricating. Cab is almost done with dash final fitting and defroster the last hurdles. I'll start on pickup bed next. I hope to get in paint before winter.
Is it a 1st series COE (Cab over engine), or 2nd series LCF (Low Cab Forward)? Any pictures ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Crusing in the Passing Lane
A 3/4 ton pickup of the same style would be a good place to look for a compatable frame, should almost bolt right up. Easy to get modern brakes, power steering, etc.
