Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Tronman), 222 guests, and 5 robots.
Topics128,289
Posts1,058,583
Members48,492
Page 95 of 177 1 2 … 93 94 95 96 97 … 176 177
Old 216 pulled out of the truck, now the process of cleaning, degreasing and painting the engine bay, have 5 or 6 weeks until my 235 is built and transmission gone through. Hopefully back on the road by August 1
Found me a piece of vacuum tube for the brake booster.
Oh yes, you're going to get a bolt by bolt narrative on this one when I can!
New cross sills arrived from Mar-k so I can put the bed back together. In the 2 years since taking it apart we managed to lose the original ones but, they are sure to show up as soon as the news are installed.
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
I thought that only happened to me. lol
~Jim
Did touch up paint work to the running boards I scratched up hauling it to the weigh station on the stupid trailer with those low sides!
I put new padding and an LMC seat cover on my seat. I think it came out pretty good for my first time.
Click here and tell me what you think
Wow!
Nice job indeed !
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
I always liked the roll and pleat look. Good job1
~Jim
Thanks guys, Here is another recent project. I found a recipe for whats supposed to be home made lizard skin, the sound and heat insulator. I haven't really got to test it yet because I haven't put the doors back on. It may fall off in 6 months but it sure looks good for now.
I painted the "headache-rack,posts,and the "box"-rails today. I forgot my camera,so I'll post some "After" pic's tomorrow. I might highlight the posts with "Indian White",to match the grille and mirrors. Not quite sure yet. "Tater"'s lookin' purty,now!! Thanks for looking!
Mo' Tater
I assume your secret recipe for "Lizard Skin" is exterior latex house paint with ceramic micro spheres/balloons added in. Looks good, hope it lasts.
You assume correctly.
Now that did turn out really nice, do you do upholstery work for a living, if not, you should.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
No, this was my first crack at it. I ordered the seat cover though, I didn't make it. I did start with a bare seat frame and springs. I found a kit online with everything needed to pad the seat.
Started my truck for the first time after working on it for nearly 4 years.I feel like a teenager with their first car. I am very proud of myself this is my first project and complete wiring job and it started the first time.But i do have one issue im not showing oil pressure on my mechanical after market gauge. i installed it in the block where an electrical oil pressure sensor was.any ideas as to what is going on here.
I am so pumped up im Beside myself. yahoo
Check your wiring, something may be loose. I'm sure you've aready thought of this.
~Jim
yahoo
Not the right forum for this question, but check for kinks in the line. Loosen it up at the block and see if you have oil there, it could be plugged in the block, or it could not be pumping oil.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Please post your questions in the appropriate forum. Please don't answer questions in this thread.
Busy day today. I adjusted the hood & fenders. Finally a nice fit. Also put the grille together, picked it up the other day from a friend that powder coated it. Also finished up the interior. A few more adjustments & install the grille & I should be on the road... drive
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
Sorry Cletis frown
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
After a year of working on the right side inner cowl panel, I have it welded in. I have now sanded down the inner fender and treated the inside of the fender with Eastwood's rust encapsulater. That topped with a coat of semi gloss paint. The engine side was sanded and shot with a gloss paint. The outer fender was sanded down on the inside and was shot with two coats of same rust preventive, and then top coated with flat black paint. tomorrow I plan on sanding down the outside of the outer fender, and depending on weather and motivation, I will treat it with phosphoric acid the shoot with a couple of coats of primer.
So jimmy D, where are the pictures?
~Jim
Moderator
Happy Birthday Leo
Moderator
Finally got rid of the skinny bias plies and put on a set of radials. I bought 6 very good used Michelins for $125 at the flea market. 85/215R16, slightly taller than the old tires.
I took my seat to the upolstery shop 2 weeks ago. (A good friend of mine) Selected the material, and said "no hurry"! He called a week later and said it was done! Great job, at a super resonable price! It's now sitting in tbe bed of the truck under wrap as I have a few other projects to finish. As soon as they, are completed, I will be focusing all my time on finishing up the interior, and complete wiring harness install!
Stranger
Frank in Iowa
"Mater's Cousin"
More pix in Photobucket
Slick, My hood needs adjustment big time... Maybe you could let me how you did it and what you did... Maybe this topic should be on a different forum ?
Mark
1949 Chevy 1/2-Ton
Lucielle
Dogface, most of us has "been there" on the hood adjustment, me included. Did you read the tech tip article? Its still challenging but I was surprised in the end, after days and weeks of working on it off and on. Then, one day, the stovebolt stars all lined up and it came out great. PATIENCE is the key word here.
ditto on looking in tech tips.
Also remember these were work trucks and didn't line up like they do on today's truck. Back then close was good enough.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Hooked up the dome light today. My bride and I went to dinner at a friend's the other night and the dome light wouldn't work. Hmmm.. Checked the bulb. Good. Checked for power- no power. Traced the wire down to the fuse box and found a nice clean cut off wire labeled "CRTSY". Doh! I never got around to connecting it to power.
At least it wasn't something critical like a brake line!
well, it wasn't "my bolt" but I did finish rebuilding the hinges on a 50 pickup. Some broke some just frozen in time. They still had the original pins in them....well, what was left of them. Whew, I'm getting to old for this hot weather. I think I'll send the next guy to someone else. Anyway, I'm finished and all is good. Whew, they were a booger.
cleaned off 71 years of stuff on the leaf springs, rear end and torque tube. I need a shower......
Alvin
I did read the tech tip. The hood is on my list but a few other things come first. I guess the new clutch and TO bearing were either bad parts or put in wrong cuz it still screams at me as I ease the clutch out. Also seem to have a broken speedo cable. My wrench friend recently ruptured a disc in his back too...so I wait or find a new guy.
As to the hood...are the springs and hinges two separate parts? I already have and use the hood hold up rod. Maybe if I remove the springs it'll help ?
Edit:
I now see that the springs are completely separate from the hinges...I think they'll be easily removed but dunno if it'll make any difference. One of the hinges, however, looks like it has a curve in the support which should rest on the cowl/firewall but is about 3/8" too high. I should address that too. I hope NOT to have to take the hood off to do this. The fenders cannot be moved since some PO welded them to the body for some unknown reason. ?
Mark
1949 Chevy 1/2-Ton
Lucielle
Cleaned inside of distributor. It is amazing that old grease and mouse turds keeps the centrifugal advance from working too well.
1952 Chevy 3/4 ton
1948 Simplex Motorcycle
1930 Ford Model A Coupe
1928 Ford Model A Station Wagon
finally found and purchased a set of 1955 4400 series emblems on ebay for $27, been hunting for a set for two and a half years grin grin
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Still recovering from the rotator cusp surgery. One handed sanded down the right rear fender and bed side to bear metal. Had my son load them in the truck for me and we took them down to the plant and media blasted the nooks and cranies where the disc wouldn't fit into. Hot water washed them, dried them, brought them back home to spray the rust inhibitor on them.
Not a bad way to spend a Father's day morning yahoo
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
got my emblems today, they are better than i ever imagined yahoo
it's the little things that just tickle me pink grin
Indy wink
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Took off the hood springs, which were Chinese anyway, that didn't work at all, and now the hood fits MUCH better. I need to adjust the latch some though. Now just have a tiny extra bit of gap on the right at the cowl... Yippee !
Mark
1949 Chevy 1/2-Ton
Lucielle
Picked up my radio from a guy who brought it back to life for me.
It was a 2 hour drive up into God's country, a great lunch with he and his wife and then a beautiful drive back home.
All in all, a great day. And we do live in the one the beautiful parts of the country. A great day off.
Thanks Fred.
"Howard"
I'm glad you got it to fit.
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
