5 members (Wrenchman, 52Carl, Waveski, Bill Hanlon, fonz8261), 63 guests, and 3 robots.
Topics128,261
Posts1,058,329
Members48,485
Hi All,
So, while I am redoing all the brakes, I jack up the passenger rear side 3 or 4 inches. Come back next day and there are two quarts of gear oil leaked from the driver side rear hub.
Does this mean a bad wheel seal? I didnt notice a leak before.
Or could a clogged axle vent allow oil to bypass the seal if the axle is tilted? The vent was gunked up.
I hadnt planned on working on the drivetrain yet, Should I fill-er-up and hope for the best? Or will I ruin my new shoes?
thanks!
52 3100 project
54 3100 / 3112 ice cream truck, next project
Time for a seal replacement.
as remo gaggi said in the movie casino "why take a chance" should you get a portion of oil on your linings you be replacing them again. since your there it would be a good time to replace them. they are'nt expensive or hard to change.
Thanks, digging a hole in the desert for the old seals.
Or in the words of Mike Ehrmantrout, "no more half measures".
52 3100 project
A stuck vent would not cause a leak as its job is to relieve pressure in the differential while driving. As the truck was not driving I would think seal. Nonetheless you should make certain the vent is free. And you can't just change the shoes without the seal as it would only happen again.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
5 Online: Content
While you have it apart, check the axle bearings and the portion of the axle that the bearings roll on. Your new seal won't last long if you have excessive bearing wear.
I had a groove in my axle from the seal believe it or not. I was told there was no way to fix it so I had to find other axles which was not easy. Someone had mentioned a Speedi-Sleeve or cold welding (?) but again these ideas were nixed. I would love to have a way of repairing the grooves.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Thanks all, I ordered wheel seals from Napa and a gasket for the pumpkin, and have the manual.
Do I need to buy or improvise a puller?
52 3100 project
Its nice to have a seal puller but "most" of the time I can pop them out with my big screwdriver which is always near by. Generally you can get behind the seal and pry against the top fo the housing and they'll pop out.
Can of worms. I pulled the axle, and a piece of bearing race and three bearings came out with it. Dont suppose I can put the loose bearings back in... So, need to get new bearings now.
52 3100 project
I ended up having a 1/2 inch wide spacer made at a machine shop. This allowed the new bearing to move out on the axle to a non worn spot. It also moved the seal out. The seal was 1/2 the thickness of the old leather type. Another fix would be to bore the axle housing deeper. Another option might be to hard chrome the axel and regrind it. I called all over the USA. No one would make new axels for a 46 chevy.
Hi All,
any preference in manufacturers? Timken, National, or BRG? Napa is most expensive
Advance Auto - National Cylindrical Outer Race Part No. R-1502-EL
NAPA - Part Number: BRG R1502EL Product Line: NAPA Bearings
Autozone - Timken/Wheel Bearing - Rear Part Number: R1502EL
52 3100 project
best to do the bearings and seals while you are there. I went with roller bearings in lieu of stock 'ball' bearing.
Any tips on which way faces out on the seals?
Side with the seam or side with the bend?
52 3100 project
Speedy sleeves work for that application. I don't know why you were told otherwise.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
Looks like the differential cover was on wrong. There are grind marks on two sides of the inside of the cover - must be from the ring gear?
How does the cover go? I presume the two bulges in the cover are supposed to line up with the ring gear? Does the filler plug end up higher or lower than the center of the cover?
52 3100 project
On page one of my photo bucket you can see the diff. Ring gear is on the left and the fill plug below center.
When I did my 53 the only seals I had available were National and Chicago Rawhide. One has a wider flange which makes it better. But I forget which make.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
