7 members (Hanks custodian, 2-Ton, TUTS 59, Otto Skorzeny, festerhairball, HandyAndy, dt235sd),
83
Mod | | | Forums66 Topics128,060 Posts1,055,836 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 5 New Guy | | New Guy Joined: May 2013 Posts: 5 | I have a '53 3100 panel truck; I want to replace the springs on the upper hinges which keep the driver/passenger doors open. Is there a trick to removing the hinge pin? I can move the pin about 1/4", there is no rust, they are not bound, I do not see any set screw.
thanks Larry | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Did you check the tech tip section?
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If I understand what your asking, take the hinge out and replace the pin and put in the horseshoe shaped door checks. | | | | | Joined: May 2013 Posts: 5 New Guy | | New Guy Joined: May 2013 Posts: 5 | yes, this is what I want to do. I can't get the pin out of the hinge. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | yes, this is what I want to do. I can't get the pin out of the hinge. Sometimes they fall out. and sometimes you have to drill them out. Cleon | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | Heat, punch, BFH, no cussing (it doesn't really help), and don't burn your hand.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | HEAT....YES. I've built a few of them and just got plain sick and tired of trying to knock them out. I have no torch so I just take the hinge to a friend of mine and he heats it till its Cherry Red and then WHACK. A couple licks with the punch and hammer and they're out. Its well worth the time to use the HEAT. Plus, it makes redrilling the holes for the new pins a lot neater and straighter.
No one has mentioned it and maybe I misunderstood but are you trying to do it without taking the hinge out??? IF so, don't try to kid yourself. Take the hinge out and then have at it. | | | | | Joined: May 2013 Posts: 5 New Guy | | New Guy Joined: May 2013 Posts: 5 | I did take the hinge out and put it in my vise; although I am sure that there are people out there who would try to do it on the truck.
I did try heat, but I only have a propane torch, certainly didn't turn it red hot. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... I tried it with a small propane torch and mapp gas but it just wasn't enough. Ruined one hinge and that's when I said "no more". I will either get tanks for my new "big torch" kit or have someone heat them up for me. Got to be rosy/cherry red. | | | | | Joined: May 2013 Posts: 5 New Guy | | New Guy Joined: May 2013 Posts: 5 | | | |
