4 members (lumbersawyer, Phak1, Gazz, 1 invisible),
107
Mod | | | Forums66 Topics128,093 Posts1,056,463 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 97 | Deconstruction of my 42 has progressed to the frame and suspension. Any of you experienced Bolters have some tips for suspension removal? These parts will be going back on as I am doing a restoration
thanks | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | What kind of information are you looking for. It all pretty much just unbolts. I am sure we can share what parts on our trucks were worn and that sort of thing. I found zip lock bags and a permanent marker worked great to keep track of parts. The more photos the better. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | BE CAREFUL. Take your time. A good shop manual would be a big help as information to if you have one, or http://chevy.oldcarmanualproject.com/ I think you can find what you need here as well. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Support the frame evenly and let the suspension sag to its fullest before unbolting anything. Remove or support the axles, then start working on the springs. It can be a little awkward since all this stuff is big and heavy, just make sure there isn't any spring tension in the springs when you start unbolting stuff.
And definately keep your fingers and toes out from underneath this stuff when you start dropping parts!
Jeff | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If a bolt doesn't come loose, don't twist it off(easily done) get your torch out and get the bolt red, kills the rust, let it cool, try again gently.
