2 members (fonz8261, Hotrod Lincoln), 122 guests, and 0 robots.
Topics128,113
Posts1,056,279
Members48,439
#945202 05/23/2013 7:45 AM
Deconstruction of my 42 has progressed to the frame and suspension. Any of you experienced Bolters have some tips for suspension removal? These parts will be going back on as I am doing a restoration
thanks
What kind of information are you looking for. It all pretty much just unbolts. I am sure we can share what parts on our trucks were worn and that sort of thing. I found zip lock bags and a permanent marker worked great to keep track of parts. The more photos the better.
BE CAREFUL. Take your time. A good shop manual would be a big help as information to if you have one, or
http://chevy.oldcarmanualproject.com/ I think you can find what you need here as well.
Support the frame evenly and let the suspension sag to its fullest before unbolting anything. Remove or support the axles, then start working on the springs. It can be a little awkward since all this stuff is big and heavy, just make sure there isn't any spring tension in the springs when you start unbolting stuff.
And definately keep your fingers and toes out from underneath this stuff when you start dropping parts!
Jeff
My 1953 Chevrolet
1947.1 Gallery
Crusing in the Passing Lane
If a bolt doesn't come loose, don't twist it off(easily done) get your torch out and get the bolt red, kills the rust, let it cool, try again gently.
