| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94417 01/24/2006 2:57 AM | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I'm about to buy a new wiring harness for my 1950 1/2 ton truck. Several of the specialty suppliers have wiring harnesses costing in the $400 range. What is the difference between those and the EZ wiring kit for $165? Are there additional components included? | | |
#94418 01/24/2006 4:36 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | IIRC, the $400 is done as original, i.e. with cloth insulation and loom.
The $165 version is done with modern materials, i.e. rubber and/or vinyl insulation and loom.
Both should work equally well in your truck. | | |
#94419 01/24/2006 4:59 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is a thread on this at hotrodders.com. Several of the manufacturers have responded. You may have to sign up to read it. wiring harness thread | | |
#94420 01/24/2006 6:50 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I checked the hotrodders.com thread. Don't get caught comparing apples to oranges. I followed one of the most popular recomendations made in the thread (Painless) and they sell hotrod harnesses and they don't offer one for your application anyway. If that's the type of harness you want then go for it. If you want a restoration harness with period correct materials, I've had personal experience with http://www.ynzyesterdaysparts.com/. Nearly all of the restoration harness sellers buy from YNZ & resell to you. YNZ will sell direct to the consumer. First rate product & excellent technical support.
#94421 01/28/2006 8:25 AM | Joined: Jul 2005 Posts: 32 New Guy | | New Guy Joined: Jul 2005 Posts: 32 | I personally went with the EZ Wiring kit because I wanted the fuse box. Not original, but it works for me.
If you decide to go with the EZ Wiring kit, check out Alan Horvath's website to see his electrical project. | | |
#94422 01/29/2006 2:23 PM | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | When you installed the EZ Wiring harnesss, was there anything you had to buy separately? Did you have to use any of the original wiring?
I'm not looking for original styled harness, so I'm definitely leaning towards the EZ or Painless wiring.
Thanks for the response. | | |
#94423 01/29/2006 6:17 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | RedGreen, also check out hotrodwires. Basically the same as EZ and Painless but less $. Google their website. | | |
#94424 01/29/2006 11:39 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, RedGreen I'm real happy with the EZ-Wire kit I put in my truck. I added AC and plan to put in power seats, etc., so this kit made good sense for me. The wires and coatings are all top-quality materials, too! Click Here to check out my checklist of all the things you may want to get before you start. Click Here to check out my photo-diary about my rewiring project. Have fun!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#94425 02/08/2006 3:22 AM | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Look at Hot Rod Wires ( www.hotrodwires.com). Little things like soldered connectors in the fuse block make it a quality kit, direct form the guy that makes them.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
#94426 02/08/2006 4:48 AM | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | We have looked at the various vendors for harness, but since I'm doing a big bolt truck none of them appear to fit the need. I'm restoring to orginal, with some small changes, like using a plastic coated wire. I beleive that if your orginal fuse panel is good, then reuse it. I didnt want a bunch of extra curcits in the new one, as theres no plans for things like power windows and AC. I have all the factory harness, so I'll just make it wire for wire, solder the ends, and should end up with a nice looking product. | | |
#94427 02/08/2006 3:27 PM | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | redgreen, I recently stripped a 84 K5 Blazer in prep to build a mud pit truck. I stripped all the wire loom, underhood, dash, and wires to the taillights etc, this is a good easy swap wire loom along with fuse block for the old AD trucks. You could also use the tilt column if your not restoring to original. About anything will work from 63 up, if it had an original alternator. resto44 | | |
