Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (klhansen, EddieD, Tyler Watts, KEVINSKI, UtahYork, 2 invisible), 43 guests, and 4 robots.
Topics128,009
Posts1,055,291
Members48,419
#940218 05/02/2013 12:46 AM
I
I Offline
If I order a '63 thru '66 wiper switch out of the LMC Truck catalog will this work for my 1966 C60? I mean, LMC truck only sells parts for 1/2 and 3/4 tons. I don't know if there is a difference between these switches going up to a 2 ton. Thanks for your help!
Iron Clad #940352 05/02/2013 3:54 PM
3B Offline
Hy Iron Clad, according to my parts book, 64 through 66 are the same, single speed and two speed siwtches are different from each other, and adding the washer function also changes the switch, hope that helps.
Iron Clad #940410 05/02/2013 9:35 PM
I
I Offline
Thanks 3B. My switch is a 2 speed. I'll have to check to see about the washer function. So it sounds like I can order a 1966 wiper switch for a 3/4 ton and it will be the same for my 2 ton.
Iron Clad #940455 05/03/2013 12:10 AM
R Online: Content
I'm sure all those components would be the same regardless of what size the truck was. I couldn't imagine why they would be different.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Iron Clad #940468 05/03/2013 12:47 AM
I
I Offline
Well, a switch is a switch I guess, LOL....I just hope they are the same diameter. I didn't want to alter the dash hole. Also, when it comes to working with metal, no problem, but I'm an electrical dummy....
Iron Clad #940681 05/03/2013 10:19 PM
I'm sure the cabs are inter-changeable,(for the Chevys,anyway),from '60-63,64-66. I used a '63 pick-up,(c-20),harness,for use in a '60 2-ton,and had no problems with any of the connections,including the dash. This was the last year of the curved windshield,and the wiper arms were inter-changeable,as well. Hope this helps.
Mo' Tater
Iron Clad #940792 05/04/2013 12:30 PM
I
I Offline
Yep wetwilly that helps, thanks! I wanted to make sure before spending the $39 for the switch (not including shipping), LOL....
