| | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Does this look like an original horn to anyone? It supposedly came from a "bone stock" '49.
Last edited by cletis; 04/24/2013 10:24 AM. Reason: deleted link to expired ebay ad
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | No But you never know, if you are interested in it, ask the seller who made it. If original, it was made by Delco and would have that name on it somewhere. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It definately does not look like the one on my 48, or any other AD truck I've seen unless it came off of a tractor size truck, Scott | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Might be, but off a 1 1/2 or 2 ton truck. Denny G
Denny G Sandwich, IL
| | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | I have several of them that were on my trucks from the 3100 to the 6400. I beleive they are a factory upgrade horn, I also have the smaller ones that mount on the firewall. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There seems to have been one "trumpet" style Chevrolet horn. That style horn was standard from 47-52 and was mounted on the intake manifold. There were a variety of seashell horns, due to the paired high note and lo note, and the left and right mounts, and different mounts on cars and trucks. The dual seashell horns were mounted in a variety of locations but the the firewall over the deluxe heater hole was the GM-designated location. In 1953, a single seashell horn was standard and it was mounted on the intake manifold. In 1954, a single seashell horn was standard and it was mounted on the grill side of the radiator frame. That eBay horn looks a lot like this horn and this horn. My guess is that eBay set-up has the wrong horn mounting bracket? | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My '52 has the trumpet horn as shown in pictures by Tim. But, it doesn't work. Mine was mounted on the inner fender.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I will tell you they are easy to disassemble and work on. You may just find the circuit needs repair or just a horn adjustment and good cleaning. It's worth a shot to try and fix it.
Drew
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | last year on the 40 the klaxon blew up hundreds of miles from home. luckily i knew someone that had an extra and bought it. every yaad i look in weather it's a gmc of chevy they were removed for some reason or other just keep looking
