7 members (Charles in CA, 55shaker, Gray_Ghost, Guitplayer, Wally / Montana, JW51, Otto Skorzeny), 123 guests, and 1 robot.
Topics128,052
Posts1,055,724
#219904 11/16/2006 10:34 PM
Does this look like an original horn to anyone? It supposedly came from a "bone stock" '49.
Last edited by cletis; 04/24/2013 10:24 AM. Reason: deleted link to expired ebay ad
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#219905 11/17/2006 12:40 AM
No
But you never know, if you are interested in it, ask the seller who made it. If original, it was made by Delco and would have that name on it somewhere.
#219906 11/17/2006 12:45 AM
It definately does not look like the one on my 48, or any other AD truck I've seen unless it came off of a tractor size truck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#219907 11/17/2006 2:38 AM
Might be, but off a 1 1/2 or 2 ton truck.
Denny G
Denny G
Sandwich, IL
Tom R #938135 04/24/2013 1:55 AM
I have several of them that were on my trucks from the 3100 to the 6400. I beleive they are a factory upgrade horn, I also have the smaller ones that mount on the firewall.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
Tom R #938150 04/24/2013 7:25 AM
There seems to have been one "trumpet" style Chevrolet horn.
That style horn was standard from 47-52 and was mounted on the intake manifold.
There were a variety of seashell horns, due to the paired high note and lo note, and the left and right mounts, and different mounts on cars and trucks.
The dual seashell horns were mounted in a variety of locations but the the firewall over the deluxe heater hole was the GM-designated location.
In 1953, a single seashell horn was standard and it was mounted on the intake manifold.
In 1954, a single seashell horn was standard and it was mounted on the grill side of the radiator frame.
That eBay horn looks a lot like this horn and this horn.
My guess is that eBay set-up has the wrong horn mounting bracket?
Tom R #938203 04/24/2013 11:41 AM
My '52 has the trumpet horn as shown in pictures by Tim. But, it doesn't work. Mine was mounted on the inner fender.
Tom R #938207 04/24/2013 11:49 AM
I will tell you they are easy to disassemble and work on. You may just find the circuit needs repair or just a horn adjustment and good cleaning.
It's worth a shot to try and fix it.
Drew
DavidF #938211 04/24/2013 11:52 AM
last year on the 40 the klaxon blew up hundreds of miles from home. luckily i knew someone that had an extra and bought it. every yaad i look in weather it's a gmc of chevy they were removed for some reason or other ohwell
just keep looking
