5 members (1955 1 Series, Shade Baby, Oswald, Wayne67vert, Ponchogl), 110 guests, and 3 robots.
Topics128,261
Posts1,058,345
Members48,485
#935377 04/13/2013 10:18 AM
Started playing with the '42 dump and noticed the brake lights do not work anymore. They worked last fall when i parked her inside for winter. Checked all the bulbs,grounds,ect. Can the brake light switch go bad? Thanks, Mike.
alltruck72 #935378 04/13/2013 10:29 AM
Certainly can, the electrical contacts can corrode just sitting
and oxidation is non-conductive. Simply disconnect one of the
wires and chech continuity with a multimeter. If it well key
the multimeter it will key the stop lights.
If you need one they should be avalable for not to much from
the old truck vendors and your FLAPS might even have one or be
able to order one.
dg
Denny G
Sandwich, IL
alltruck72 #935385 04/13/2013 11:05 AM
I have had very poor luck with the counterparts version, two failed in a year. So I sourced one from NAPA, more expensive but it works great and is much higher quality. Ask for part number #SL128.
alltruck72 #935390 04/13/2013 11:29 AM
Cole Hersee #8486, pins point up when switch is mounted
Cole Hersee #8487, same but pins point down when switch is mounted
either about $20 from NAPA where I live
alltruck72 #935423 04/13/2013 2:34 PM
In '42 was the brake light switch on the floor or attached to the master cylinder? My '47.1 COE has the hydraulic actuated switch.
Jeff
My 1953 Chevrolet
1947.1 Gallery
alltruck72 #935430 04/13/2013 3:01 PM
42-47 manual shows mechanical switch, although I do recall some years or models with the hydraulic switch, maybe a big bolt thing or COE?
