2 members (jmoore, 68ironhead),
86
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Started playing with the '42 dump and noticed the brake lights do not work anymore. They worked last fall when i parked her inside for winter. Checked all the bulbs,grounds,ect. Can the brake light switch go bad? Thanks, Mike. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Certainly can, the electrical contacts can corrode just sitting and oxidation is non-conductive. Simply disconnect one of the wires and chech continuity with a multimeter. If it well key the multimeter it will key the stop lights. If you need one they should be avalable for not to much from the old truck vendors and your FLAPS might even have one or be able to order one.
dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have had very poor luck with the counterparts version, two failed in a year. So I sourced one from NAPA, more expensive but it works great and is much higher quality. Ask for part number #SL128.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Cole Hersee #8486, pins point up when switch is mounted Cole Hersee #8487, same but pins point down when switch is mounted either about $20 from NAPA where I live
Bill | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | In '42 was the brake light switch on the floor or attached to the master cylinder? My '47.1 COE has the hydraulic actuated switch.
Jeff | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 42-47 manual shows mechanical switch, although I do recall some years or models with the hydraulic switch, maybe a big bolt thing or COE? Bill | | |
