7 members (chevy51truck, MickeyP, Otto Skorzeny, LAROKE, TUTS 59, Gdads51, Oswald), 96 guests, and 0 robots.
Topics128,049
Posts1,055,695
#931275 03/28/2013 7:42 PM
"48" 1/2 ton. I re-assembled my grill since the peices came back form the body shop and figured out that the grill came off the big truck my cab came from. These grills are a little different then the 1/2 ton. It went together using the vertical brackets from the 1/2 ton. The horizontal bars from the 2 ton. I placed the assembly in the opening and it appears to fit with just a little modification to the bottom bar. Before I go to far, can anyone think of a reason not to do this other then it is not correct. This grill came out just perfect and I hate not to use it for a 1/4" difference that most people will never notice. Am I not seeing anything that will cause a problem fitting together
If you never tell a lie, you never need to remember what you said.
Bart_Bosco #931279 03/28/2013 8:02 PM
who cares about 'correct' when it looks that good?!! thumbs_up
Flxible #931383 03/29/2013 9:58 AM
Y
Y Offline
I doubt to many people will even notice the difference. Your grille looks great, and as long as it fits go for it! I'd really like to see what it looks like once it's on the truck.
Phil
Bart_Bosco #931408 03/29/2013 11:07 AM
I am in the process of painting the correct vertical bars black and re-assembling the grill this weekend to see if it all fits. as far as I can tell the bottom bar may need some modification to fit to the support. I will post a picture when done.
Bart_Bosco #931410 03/29/2013 11:26 AM
I agree, it looks great and if it fits nobody will ever know. Having put a reproduction grill in my truck if I had a good original it would be in there!
Bart_Bosco #931516 03/29/2013 10:25 PM
I could not wait for the week end. It fits. Grill and another view. If you look close, the bottom four bars are taller then the top bar. The bottom are from a 2 ton truck and the topbar is from a 1/2 ton. It took very little adjusting to fit. Now I can sleep.
Bart_Bosco #931547 03/30/2013 4:42 AM
I think it looks great Bart!
Bart_Bosco #931578 03/30/2013 8:09 AM
It looks real nice.
Thanks for posting the photos.
Bart_Bosco #931589 03/30/2013 9:01 AM
I did not realize they were that close, it makes me cry to think how many of these I have scrapped the last few years, probably 10-12!
Brad Allen #931602 03/30/2013 9:39 AM
Y
Y Offline
The grille looks great, your truck looks great! Now I have to ask, why not use the top bar from the big grille?
Phil
Bart_Bosco #931610 03/30/2013 10:10 AM
Your grille looks great.When using the big truck grille bars on the small truck grill frame work.Everything will fit fine except the top grille bar.It will look like it's smiling at you,modifying the two two side metal tabs will allow it to be bolted up without the smile.I have not done the modification,but have talked to people that have and the grilles look great.
Tim
1951 3100 Chevrolet
Bart_Bosco #931654 03/30/2013 12:16 PM
The top bar from the big grill was damaged beond repair. This top bar I used from the 1/2 ton was in excellent shape. When I set the two next to each other they looked the same. I think this worked out good. The fender has four holes that match to the top bar. I dont think they would have matched to the big grill top bar. I may hold it up there and see just so I know for sure.
Bart_Bosco #932381 04/02/2013 11:54 AM
This is a timely post if ever there was one. I have 3 grills for my 3800. The one that came on it, and its pretty beat up. A chrome one that I bought that is not badly dented, but has some kinked and twisted bars and starting to rust, and a grill from a 6400 that is pristine. I wished and wanted that grill from the 2 ton to fit the one, but everything i read/heard/etc. said no. I see now that by swapping some bars around, this may work out.
Thanks!
Bart_Bosco #932528 04/02/2013 10:02 PM
You can swap the same number bar from one to the other but each bar is different length than the other by about a 1/2 to 5/8". I learned the hard way....like I do most everything else! LOL
Achipmunk #949498 06/11/2013 12:17 AM
Yes,
They are Notched on the backside from 1 to 5 i/e top to bottom.
top has 1 notch and bottom has 5.
steve sr.
