13 members (Gdads51, Rusty Heaps, FishinToms53, MNSmith, NAPCOStormTrpr, Jon G, Otto Skorzeny, Cletus1950, Peggy M, Shaffer's1950, Leo, GDW, Hanks custodian), 99 guests, and 0 robots.
Topics128,139
Posts1,056,455
Members48,441
Page 88 of 177 1 2 … 86 87 88 89 90 … 176 177
Had the door graphic put on. My Uncle Walter was quite a guy...he raised registered Hereford Bulls for decades back in the 40's and 50's so I decided to honor him with this graphic. The phone number was actually his number in 1945. I called Monterrey Co. Hist. Soc. and they found it for me
http://s1276.photobucket.com/user/Dusty411/media/IMG_1204_zps92b6120d.jpg.html
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Dogface, I like the truck and the dog smile
Say, is that painted on or did you get a decal make??
The other day I cleaned up the rear end. Today I spent over three hours just scrapping all the old grease away with a flat head screw driver from all the moving parts in the driver side front end of My Grandfathers 3600. After really cleaning things up I greased all the fittings which took some effort. Said and done it was worth it. Im looking for a charger for my digital camera. May have to buy one but as soon as I do I will post some real pics.
Justin
http://s272.photobucket.com/user/ju...y%203600/photo1.jpg.html?sort=6&o=10
Today I am putting the engine and tranny back in the chassis .I will add pics when I am done.
I got the engine in the truck today.I have a frony mount problem to figure out,but it is in there.
Entered a car show at Texas Truck Toys in Terrell Tx, won a recog. plaque and came home.
~Jim
I was able to take it for a drive to test out all I done over the winter,calling for snow tomorrow so it will probably be in the garage a couple weeks until the salt is gone off the roads.
Brakes rebuilt, parking brake adjusted then took a nice test ride over to kville!
I got my 55.2s doors adjusted, radio installed, antenna installed, heater contol valve made and took it on its first shake down cruise and it drove very well. I used the throttle cable to operate the heater valve.
I went and bought a 1953 chevrolet 1 ton & got it loaded & hauled it home.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
Threw on a new fuel pump and started it up, let it run for a bit to make sure everything was working right and then started taking the front end apart. Got the grill, inner and outer fenders off, engine tranny and cab will have to wait till next weekend.
Hey Jim,
Congrats on winning the plaque! Way to go!
This past weekend I installed a new pin and bushing set in my driver door hinge.
I also reupholstered my bench seat with a kit I bought from Raybucks. The seat is assembled and ready to be installed in the cab but I first, need to install some lap belts for the wifey, grandbabies and me! wink
Well, yesterday I put the repaired radiator, new water pump, and freshly painted OEM Fan shroud in my 1962 C10. Fan shroud has been missing since I got the truck and I finally found one on eBay.
Today I drove it to work. :-)
I sandblasted then brake and clutch pedals
Just about done with the interior. Still undecided on painting it myself. I'd be doing it in the garage & with the gas hot water heater & furnace nearby, I don't want to blow up the house!
Robert C.
I'm a Genius in the making.
1950 3600
I'm still having some driveline issue's and the only way to diagnose is to drive it.....today I put insurance on it and applied for the antique tag. Should come in a few days and I'll be "on the road again" smile
back yard wrench turner
You will need to have it done for the Tennessee meet.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Got the grill and front bumper installed on the '59, hopefull headlights and buckets tonight.
http://s783.photobucket.com/user/jo...amp;_suid=136456574262403677439180694444
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I need to get the new freeze plugs,bell housing,clutch and pressure plate,tranny,driveline back in today.Hopefully my wiring harness will come in so I can start on that?
Well brought orange truck home from bodyshop this morning. Hood looks way better. time to get her put together.....
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
Fun Day....included new cap, rotor, plugs, wires, oil & filter. Running good!
1954 Chevy 3100 (3 window/4sp)
1966 Ford Mustang convertible (Factory K-code)
See...Ford & Chevy can get along after all!
Ordered up some custom parking brake cables for my ride.
I got both front cab corners cut out and new ones welded in.Now to do a little body work to get ready for paint
Saturday, I met Denny Graham, a frequent contributor here on stovebolt, for breakfast. He is definetely a go-to guy with a wealth of knowledge. We live about 10 miles apart. Great guy and gave me a few tips on my current resto project. I then came home and worked on my hybrid T5 swap. Gotta get some shim stock for the speedo relocation. starter shims should work.
1951 Chevy 3100
Julio,
You are very fortunate to live near Denny.
Offer to trade him your time-labor on his shop/barn/property for his time with your tougher projects - he probably has two-person jobs that slow him down.
This might get Denny settled faster with his shop/barn duties and get him back to truck projects/posts.
I've met Denny a few times myself, he's a pretty sharp cookie.
Brian
1955.2 3100 Truck
Originally Posted by Czechman
I spent 20 hours scraping 60 years of crud off my frame forward of the firewall. Then I washed it all down with mineral spirits and gave it a good coat of paint. At 61, it pretty much of an ordeal crawling around on your back for the better part of a day but it was rewarding to see it finished. One more thing off the list.
PICTURE 1
PICTURE 2
PICTURE 3
Czechman were did you get your front disk brake setup?
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
Slick, you're not likely to get a response from Woody, he sold his project due to health problems and hasn't been active here for some time
10-4, thanks Bill
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
I worked all day on the cab.It is about ready for primer,then a final sanding and paint.It won't be long.
Drove the '50 half ton to the monthly Inliners meeting last Saturday. Took all the new parts I bought from NAPA to do a complete tune up. Hadn't changed any of these out since buying the truck in '08 & I figured it was time. We installed new points & condenser, rotor, distributor cap, coil & a set of plug wires. Tried to time it but couldn't ever locate the ball on the fly wheel, but when we fired it off it ran very smooth so we figured the timing was pretty close. Didn't want to take time to crawl underneath to remove the cover & clean off the flywheel to find the mark. A project for another day.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Drove to Spokane to get a new 4 post lift for the shop. Sure going to make bleeding brakes & oil changes alot nicer....
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
^ lucky dog. I'd love a lift but my garage is a concrete cell under the house that's about the same vintage as my truck whose roof only clears the celling by a couple inches. Best I'll get is a pit. ...which I might just do.
Got my fresh air heater done.
http://farm9.staticflickr.com/8375/8589090789_db4e596d98_b.jpg
http://farm9.staticflickr.com/8392/8589089819_f7295c64a0_b.jpg
...but the real accomplishment was getting my truck's blog moved off wordpress and onto another server. It was essentially a crash course in PHP and CSS. I made some minor changes/improvements in the design and UI and it's currently live and functioning. Now all I gotta do is get around to posting the latest updates (heater, horn, new wheels, etc)!
Enjoy! www.rustyfiftyone.com
Nice lookin heater, i just redid mine as well.
Awesome looking blog too, just spent the last 20min going thru the whole thing. Keep up the good work!
Chooglin
1954 3600
[/url] www.tors54.tumblr.com
Thanks, Chooglin! cool
BLUEMEANIE,
It will come in handy & well worth the investment($2250 + fuel to get it). Sure beats crawly around on the floor....
I'll post some pictures of the lift, finished putting it together last night & will test run it tonight.
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
Great looking heater!!!
~Jim
Originally Posted by Slick69
BLUEMEANIE,
Let's keep this about progress on our trucks. Please post the lift pics in the Tools forum.
Thanks.
^ Sorry. smile
...back on topic...
Thanks! I hope to get it installed on friday.
I unloaded my new cab and fenders that just arrived from New Mexico!
I'm ecstatic at the condition and had a great experience with the seller and shipper.
Not quite what we're used to finding in the North East and I got a great deal.
See pics in my blog below.
