| | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Is it worth putting the time and effort in fixing the front fenders ,or just buy fiberglass? My fenders will need some metal work.they have some small dents and dings and some rust that need repaired.I have the ability but don't know if I want to put the work into them. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | My 2 cents, If the fenders are mostly there,aka better than 75% And You Can do the work, FIX EM! You got it this far apart. Dosn,nt look like Your in a mad rush anyway. Obvious You are not making a,and I Despise the term,RAT ROD.
Repops are avail. but Not the same as the Original steel It,s rewarding in the end result. steve sr. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Down side to fiberglass fronts is the structural nature of these trucks, the front end functions as a structural unit. Radiator support-fenders-fender supports-cab I think long-term they will be trouble. JMO. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | To add to what Brad is saying. It doesn,t look like You are making a trailer queen out of it,if so, fiberg.semi ok. As a usable,functioning truck,fiberglass will crack cause of the structure and flex that He is taking about. steve sr. | | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | Metal Shaper, I would go as your a.k.a. implies! I agree with steve sr and Brad Allen on their thoughts 100%!!! I have taken fenders that were less than 60% useable and brought them back. Same with tailgates and a few sets of doors etc.. The satisfaction to say "I did the work" is its own reward!
Though, if time, is concern and you have the cash.... It is your truck! | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I would NOT use fiberglass parts. Just study the average KW or freightliner big rig, most that have some years on them, the fiberglass hood fender combo's are cracked. Fiberglass is okay for cutting a few corners repairing some things, for corvetts, and boats, thats it. And besides goto some of the outfits, like filling station, LMC truck parts etc. you can usually get brand new steel parts. And why would someone say the repops are not as good as the original steel? The gauge is good, and solid metal is way better than metal with rust throughs. Plus they are even painted where the factory never did.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Leave the fiberglass to the boat guys
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | Depends on your time and what its worth. I have had fiberglass fenders on all four corners of mine for 13 years with out problems. One thing I would do different is have the underside of them heavily coated with bed liner or undercoating. Rock "star" marks are in the front fenders from being thrown off the tires. I suspect steel may do the same thing, but never having them I wouldn't know. I didn't want to look for steel fenders for years, so that was my reason, and at the time, they were only $125 each. I couldn't have fixed mine for that. In all the years I have had mine at shows or meetings, no one has ever come along and said anything about fiberglass, most of the time I point it out to show the wider rear fenders. And for over all value of the truck, I doubt it makes much difference.
Joe | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I'd stay with the original fenders if at all possible. It's nice being able to say the truck is " all steel " as there aren't many out there. You may also have some fitting issues when it comes to glass parts - kinda a crapshoot it seems. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | From your pictures on Photobucket it looks like you are working a 41-46. I'am in the same project with a 41. No steel repo fenders front or rear are available from any of the venders that I know of. You see them on Ebay now and again (cost and conditon)with most are a concern. If you have the talent put it to use and you will be more pleased with the result and the structure of the front end will be a lot more solid. I have re worked mine as well as the bedsides, tailgate, doors, top, and rear of the cab. Really pleased with the results. And I know that they will last longer with use. JMO.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Thanks for the replies .I will have to look them over again and decide.I have worked in sheetmetal and fabrication for close to 30yrs.I can fix them, but am getting a little lazy as im getting older | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have to add I use fiberglass on my rears and I am very satisfied with them. But for anyone who has put one of these front ends together you have to push, pull, prod, cuss and drink to get through it. Then think what that glass is doing as you go down the road it is literally tearing every bolt hole apart. It is not the right application for these trucks. It will eventually as the miles roll up lead to difficult to repair failures, the weak link is the attachment points, a bolt hole in fiberglass has a limited life at best. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...I'm with Joe H. on this one. I've ran fiberglass front and rear fenders AND running boards on my 37 for 12 years now. I drive my pickup and at high speeds on the interstate. I'll even admit I do not have the back brace on the rear fenders so I get a little "shake" when idling. However, none of the glass has cracked or starred yet. I'd do it all over again. It certainly more economical than what I would have paid a body man.
If metal shaper is not a "purist" and getting old like me then I'd recommend the glass and say drive it! JMO. | | |
