0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Rotate your tires, Im running radials
change your spark plugs
Grease king pins
Tune up
I realize some of these schedules are in the manual, just curious what real world pratices are,
I have about 6500 miles on my radials, have not rotated them yet.
My 50 been running well, avg 16 MPG the last 3 months. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Frequency is a factor of how much driving you do. On avarage I put 3000-4000 miles on my truck per year. For the last 6-7 years I have been changin oil at the end of the trucking season. Typically when I return from the Tri-State show (last of the year) I pull into the garage and remove the drain plug.
During the winter I rotate the tires and get my grease gun out and spend a morning greasing it up.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are about 19 grease points/fittings that are supposed to be greased every 1,000 miles (4 of which are the king pin grease points). I do all the grease points (including the brake/clutch pedal shaft, of course) once a year when I get the truck inspected in the Spring. Turn the distributor grease cup and check transmission and rear-end levels. It's been about 9,,000 miles since I packed the wheel bearings, so that gets done this year. Tune-up, including valve lash this year, and maybe adjust the steering gear. It it supposed to be a good idea to change the oil before winter (hibernation time for my truck). Change the oil and run the engine until it is warmed-up - this supposedly reduces the amount of acids in the oil (maybe not a big deal with modern oils?). | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Same as Sweet and Tim end of every year lube,oil,good cleaning inside and out,wax job once a year in the spring.I have not rotated tires in two years I should do it this year.
Pete
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Most fast lube places recommend to rotate your tires every 6 thousand miles. At least every year and or 12 thousand miles is a good guide. Spark plugs should last 50 thousand miles with the old AC 45 spark plugs and no carb problems. New cars last 100k miles. That said I would tune up at 50k miles and follow the 1000 mile guide for greaseing all fittings. I realize this is my opinion. Mike
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | I do a tune-up once a year, oil change and lube twice a year. That's a good time to look for any leaks and check stuff out. My 38 ain't a daily driver - but I do start it up weekly and cruise around the neighborhood in the winter months (weather permitting). I always take look under the hood before a drive, and I will make sure all the lights are working if I will be driving at night. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | In my opinion, if you drive it regularly year around I would change the oil every 3 months. I would also check the point gap and clean points and re-adjust every 3 months if driving on a regular basis. Rotate the tires once a year.
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | If your truck is stock or mostly stock, go with what is in the manual. BillyBob Maintenance log -W | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Oil and lube every 1000 miles. No oil filter. Change the in-line fuel filter and oil bath oil annually. Oil the generator every 500 miles and turn the grease cup on the distributor now and then. Lube hinges and door/window regulators annually. Rotate tires about 3000 miles (bias-ply). It is all cheap insurance. | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | I change the oil every 6 months but average less than a thousand miles a year. I have heard reference to the distributor grease cup but where is it? '53 235 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have heard reference to the distributor grease cup but where is it? '53 235 ...click... top left | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Ahhh... now I remember that. Thanks DADS50! | | |
