| | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Hey guys, Where do you reckon I can find an e-brake idler pulley for my 57 3100? I did a quick check at Jim Carter with no joy. regards, Leon
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | never seen them anywhere, I think you're looking for used
Bill | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Someone posted on here in 2005 or 6 that these pulleys can be found at Home Depot/Lowes? The diameter is close to ones use on garage door spring/cable setups. While not factory, it looked pretty close as I recall. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | After I posted, I found that they are available from several of our suppliers, Classic Parts , Danchuk, Tuckers, etc. But the prices were a little high and the shipping was way off base. I couldn't find them at my FLAPS. I cleaned up the current one and it looks serviceable. I think I'll use it for a while and try to find one at a swap meet where I won't have to pay shipping. regards, Leon
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | It looks to be plastic but it should last for years. By the time you run your gas out at todays cost it may be cost effective to suck it up and just pay for something you can bolt right on.....just saying. (It cost me 5 bucks now just to drive into town. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Might also try a Marine Supply place if you have one nearby. | | |
