Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (1955 1 Series, farmallb, TooMany2count), 65 guests, and 1 robot.
Topics128,006
Posts1,055,272
Members48,418
#922565 02/24/2013 3:04 PM
Does anyone know who sells cut-to-fit E-brake cables and not lokar.
root #922585 02/24/2013 4:18 PM
1 Offline
Jim Carter
root #922614 02/24/2013 5:32 PM
Socket Breaker
Socket Breaker
root #922637 02/24/2013 6:23 PM
I guess I should have said that it has a 86 malibu rear end. I want to connect to the reg. parking brake set up 53 3100
root #922650 02/24/2013 7:22 PM
Lokar doesn't have the set up you need? If not, maybe you're thinking of Gennie Shifter?
root #923144 02/26/2013 6:11 PM
Lokars cables are what I need except, the right side is to short, needs to be 5 feet for rear end I'am using. The hole on the driver side, for the brake, comes out of the fwd. side of the backing plate and the right side comes out of the aft side. So the cable needs to be longer to hook it up. 53 3100
root #923202 02/26/2013 9:10 PM
Well, Gennie says they'll make you anything you need. http://www.gennieshifter.com/index.php
root #925513 03/07/2013 1:06 PM
http://store.controlcables.com/servlet/Page?file=cat_hardware.htm
Go to the download page on there web site for brake cable drawings and information. I had them make mine, '37 truck up front, '79 Trans Am on the back. Works perfect.
Joe
root #926526 03/11/2013 11:53 AM
Don't expect Gennie to make anything, they're basically out of business.
My 46 GMC on Photobucket
root #926537 03/11/2013 12:47 PM
Wow. Didn't know that!
root #926607 03/11/2013 4:33 PM
have you contacted lokar ?....seems strange they wouldnt have something that would fit..........dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
root #926877 03/12/2013 1:24 PM
Not sure why you don't want to go Lokar, but they're probably your best bet, unfortunately.
root #926935 03/12/2013 4:29 PM
I'am going Lokar, they have a 96 inch cable one. A little long but it is cut to fit. thank for help, Root
