1 members (baldeagle),
36
7
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Does anyone know who sells cut-to-fit E-brake cables and not lokar. | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Jerry
| | | | | Joined: Feb 2002 Posts: 2,892 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,892 | | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I guess I should have said that it has a 86 malibu rear end. I want to connect to the reg. parking brake set up 53 3100
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Lokar doesn't have the set up you need? If not, maybe you're thinking of Gennie Shifter? | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Lokars cables are what I need except, the right side is to short, needs to be 5 feet for rear end I'am using. The hole on the driver side, for the brake, comes out of the fwd. side of the backing plate and the right side comes out of the aft side. So the cable needs to be longer to hook it up. 53 3100 | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Well, Gennie says they'll make you anything you need. http://www.gennieshifter.com/index.php | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Don't expect Gennie to make anything, they're basically out of business. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | Lokars cables are what I need except, the right side is to short, needs to be 5 feet for rear end I'am using. The hole on the driver side, for the brake, comes out of the fwd. side of the backing plate and the right side comes out of the aft side. So the cable needs to be longer to hook it up. 53 3100 have you contacted lokar ?....seems strange they wouldnt have something that would fit..........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Not sure why you don't want to go Lokar, but they're probably your best bet, unfortunately. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I'am going Lokar, they have a 96 inch cable one. A little long but it is cut to fit. thank for help, Root | | |
