| | | Forums66 Topics128,196 Posts1,057,393 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Won my 1st trophy today at Cars for Cure by American Lung Association.  the trophy was for 'Most Unique'. The show has been mostly high end sports cars and I entered my truck to see how it would be received. Way to go Wayne! Congrats.....
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Taking out my radio to send back to Antique Radio AGAIN.... What a lemon. | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Got a pile of small parts cleaned and ready for paint tomorrow. I've got the week off so if all goes as planned I might actually get something done. I really wanna put something TOGETHER!!! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Hard work is paying off. Looks nice. | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | I cleaned up and painted a more period correct inside rear view mirror for my 37,I had installed a billet mirror so I could have a mirror. I picked up the mirror a couple years ago and finally got around to painting it,I also picked up a inside sunvisor that will work but I will have to wait until I get material to redo the interior before even thinking about installing it. | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I got the body off the frame on Sunday so Ive been laying on my back scraping and sanding.First coat of Chassis Saver on last night second coat now.Maby I can get it on the finished frame this week end.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Installed the barn door switch. Tested the tail light. Success!! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I just finished rebuilding the horn that I will sell at the next swapmeet.
~Jim
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Got the remainder of the rotted plywood sheet and rusted strips cut out using bolt cutters and I replaced the starter with a reman unit and main power cable w/ the cloth covered #1 from Jim Carter. She starts up just fine now! Still need to get another length of #0 cable and ring terminals tho so I can add the cutoff switch in. ...couldn't bring myself to cut up the expensive cable even tho it's plenty long. Make sure your cut-off switch is rated for the high amprage 6v system, otherwise it will be the cause of low current flow. Mike B  It is.  | | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | Got the spotlights back on and working. Glued the new weatherstripping on the doors. Found it is way easier to just take the doors off to glue on the weatherstripping. | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | Got the more correct looking inside rear view mirror installed,dont know what it was originally off of but looks better then the billet mirror I was using. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | The truck rolls a bit with the camper on , so today I fitted new heavy duty 4x4 shocks and that has cured the issue. | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Stripped my cab of anything and everything useful yesterday so it's ready to scrap... Hope to update blog tonight. Have a cab in New Mexico I'm buying but have to arrange shipping from there to NY Any takers?  Tj | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Got the spotlights back on and working. Glued the new weatherstripping on the doors. Found it is way easier to just take the doors off to glue on the weatherstripping. But door adjustment is easier to do without the weatherstripping in place.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Got the spotlights back on and working. Glued the new weatherstripping on the doors. Found it is way easier to just take the doors off to glue on the weatherstripping. But door adjustment is easier to do without the weatherstripping in place. When I was at the point of weatherstripping the doors I had heard so many horror stories about weatherstripping doors and thought about taking the doors off but, I had heard many more horror stories about hanging doors. That was my motivation for leaving them on.
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Had to drive the 37 around some today to make sure the new battery is all charged up and A-OK....and drove it around getting parts for the "newer" bolt! | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | I bolted my new tag on yesterday.
Only the 2nd tag it's had since I bought it almost 10 years ago... yikes! I've had it that long?
-W | | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | Got the spotlights back on and working. Glued the new weatherstripping on the doors. Found it is way easier to just take the doors off to glue on the weatherstripping. But door adjustment is easier to do without the weatherstripping in place. When I was at the point of weatherstripping the doors I had heard so many horror stories about weatherstripping doors and thought about taking the doors off but, I had heard many more horror stories about hanging doors. That was my motivation for leaving them on. Luckily I have new hinge pins and bear claw latches. Just got the bolts in, closed the doors and snugged up the bolts. Everything seems to work fine.
| | | | | Joined: Oct 2012 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 58 | I had 3.55 gears installed. | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | Got the pass side splash pan on and modifying the drivers side to clear the dual exhaust,should have it done in a couple days and will use them as tool catchers when I drop a tool tinkering on it. | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | went to the winter swap meet in Lebanon TN and scored on a heater switch, two 600x16 tires, oil filter and spotlight for the 53 chevy 3104. Had a great time.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Fished in the drivers door latch, replaced the drivers striker plate, temporarily installed the drivers inner door handle, removed the TPI plenum to access the EGR area in preparation of making some intake block off plates. Oh yeah, replaced the broken spring on the drivers door latch mechanism. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Looking really good Mark.
~Jim
| | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | Pulled the wire welder out and started welding holes! Holes in the doors from (?) many mirrors installed over the years. Holes above box step for aux. feul tank. Holes on stake pockets where tie down brackets used to be. Holes in dash from missing spotlight. Holes at rear box brace, licence plates? Holes in kick panels for (?). Pert near 40 of em!!! Prevous owners must of run amuck with a drill near as I can figure. Maybe it will stop whistlin when I drive it now! Next..... some grinding work! | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Got into the rear brakes on the 57 GMC LCF 370 today, to see what parts I need. Wheel cyl. bores look good, think I will hone and just replace the washers. Found out that it has 2 cyls. per wheel on all 4 corners and they are 1 1/2" bores on all. Shoes look good with plenty of lining left. All 4 return springs were broken, and need the inner seal. Both adjustment screws were frozen up, got them loose and oiled up. This is just the right rear, who knows whats in the left side. Ready for cleaning every thing,get parts, and put back together and head on over to the left side.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | Got the driver side splash pan modified to clear the dual exhaust and painted,will install tomorrow night. | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Looking really good Mark. Thanks! | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Disassembled TPI plenum. Put most of the parts in the soup. Made an EGR block off plate out of 1/4" aluminum. | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | Got the drivers side splash pan on and not sure if it was worth the effort but its on. | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Cleaned more of the plenum parts. Unpacked my Champion aluminum radiator to check for damage. All good. Unpacked my Classic Parts box for more necessary parts. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Well, I took the cover off the '59 rearend I picked up Saturday from a fellow bolter. I wanted it to replace the center section in my panel and what to my SURPRISE, it is a 3.38 ration....talk about a happy man. No more 3.90. Wow, the Stovebolt God was sure looking over me today. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | got my door hinge fixed thanks to the tech tip, now for the first time since i bought the truck the door works properly and no longer falls off every time i open it  !!!!!!!!!!
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Didn't get anything done but I just scored a restored early style front sway bar on ebay today. Decided on a whim to bid on it at the last minute and won. ...I'm actually surprised I got it. http://farm9.staticflickr.com/8375/8496049577_730bde2be9_b.jpgAlso bought a fresh air heater off baldeagle and finally made some updates to my blog - www.rustyfiftyone.com | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | Finished the last thing after installing the splash pans,when I ran the new brake linesafter the disc conversion I used the holes for the splash pans to attach the brake lines to the frame so I picked up clips for 1/4 inch bolts. | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | More cleaning on the TPI plenum. Had one bolt fight me on the drivers side intake tubes, gonna have to drill it. Cleaned the PCV tubes. Removed the old engine wiring harness. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Replaced the radiator on the '65. The almost brand new Champaion developed a leak. I thought poor workmanship until I got it out and discovered the leak was caused by the condensor tube touching and rubbing on the core. The poor workmanship was mine! Placed a cut ruber hose over the tube and reassembled with a new radiator. I'll have to get this one welded and then I'll put it in the '66.
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Got both rear spring bolts, bushings and shackles repaced. Welded up the rt rear frame mount and reamed to fit the new bushing. Got the bed bolts cut and ready to pull the bed.
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Took the seat back to the upholsterer to have them re-do the seams that didn't come out that well when they did them last fall. It is going to be spring here before we know and I can get back it again. | | |
