0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91867 11/26/2004 4:34 AM | Joined: Jul 2004 Posts: 13 Junior Member | | Junior Member Joined: Jul 2004 Posts: 13 | We are trying to start a 54 Chevy 4400 that is missing the battery, so don't know if it is original 6V or has been converted to 12V. What are the tell-tale signs to help me indentify which system it is. Also, in either case it is always negative ground, right? | | |
#91868 11/26/2004 4:52 AM | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Might try checking the generator for an ID/Spec tag.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
#91869 11/26/2004 4:54 AM | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | BTW where are you at here in GA?
#91870 11/26/2004 5:06 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | If it has an alternator, it's 12V. The regulator on my generator equipped truck has "12V-N" stamped on the base. (12 volt, negative ground) This code is found on the right side of the reg as you look at the firewall, next to the screw that attaches it to the firewall.
Gord 1954 1/2 ton 235 4 speed
#91871 11/26/2004 5:28 AM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | They do make 6volt alternators too but most go to 12 volt if going to the effort of changing. But check part number as suggested just to be sure.
40 Chevy 1/2 ton
#91872 11/26/2004 6:52 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | 6V alternator? They have to be pretty rare. What automotive application used that?
Here's another idea. Check to see if it has 12V headlights. Unless the vehicle was only used in the daytime, they would have to replace the headlights when they converted to 12V.
#91873 11/26/2004 7:45 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | If it has a generator, the 12v generators are marked as such at the top of the oval "Delco-Remy" tag - at least every one I've seen was marked this way. None of my 6v generators are marked as to voltage. | | |
#91874 11/26/2004 2:30 PM | Joined: Jul 2004 Posts: 13 Junior Member | | Junior Member Joined: Jul 2004 Posts: 13 | Thanks, guys. I'll head out to the farm this afternoon and check a little closer. | | |
#91875 11/26/2004 5:28 PM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | 5th Ave from the links section advertises a 6-volt alt. Not sure what the original applications are though. Changing from 6 to 12 is trivial anyway so not sure why anyone would go to all the trouble and expense to get modern but keep pushing 6 volts. but it's there if you want to.
40 Chevy 1/2 ton
#91876 11/26/2004 6:54 PM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | I see what you mean, Dennis. I bet that they use a 12v core and drop the voltage to 6v in the internal regulator. The instructions mention that alternators weren't common until the 60's (after 6v systems were already obsolete).
I agree with you; why bother with a 6v alternator? You would have to ask someone who bought one.
#91877 11/27/2004 2:23 PM | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Also look for a resistor between hot wire and coil. six volt system won't have one. | | |
#91878 11/29/2004 1:32 PM | Joined: Nov 2004 Posts: 35 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 35 | HERES THE EASY WAY, CHECK OUT THE TRUCKS BULBS HEADLIGHTS, TAILLIGHTS ETC. Heres a few #s 12 VOLT# 1156,1157,57,67,1895,2056,2057,53,89,90 6 VOLT# 63,1129,1154,55,51,87,63,81,82 I hope this helps you out! | | |
#91879 12/03/2004 4:39 AM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | All good tips plus the original Delco generator tags were either red or black depending on 6 or 12 volts , of course I cannot right now recall which is which .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#91880 12/04/2004 5:31 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Just use a 12 volt battery until you get it running and starting good. I used a 12 volt to get my 54 started so I could evaluate the engines condition, just didn't turn on any lights. It also helps it to start, after a long rest, if the engine cranks over faster. Just my opinion, Scott | | |
#91881 12/04/2004 6:33 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Be careful, Scott. You can fry your fuel gauge starting a 6V truck with a 12V battery. It's on when the ignition is on.
#91882 12/06/2004 8:15 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I made a 6V alternator a while ago by changing the diodes and voltage regulator. I was having reliability problems and it worked for a while until I decided to convert to 12V. Parts are available on line, you can convert a GM 10si alternator to 6V for about $25. It worked pretty good until a short fried the regulator. I changed the harness and used a 12V alternator.
