6 members (Bill Hanlon, Gdads51, Otto Skorzeny, UtahYork, dt235sd, Ponchogl), 115 guests, and 5 robots.
Topics128,089
Posts1,056,130
Members48,435
#91867 11/26/2004 4:34 AM
Junior Member
Junior Member
We are trying to start a 54 Chevy 4400 that is missing the battery, so don't know if it is original 6V or has been converted to 12V. What are the tell-tale signs to help me indentify which system it is. Also, in either case it is always negative ground, right?
Might try checking the generator for an ID/Spec tag.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
BTW where are you at here in GA?
Bruce
If it has an alternator, it's 12V. The regulator on my generator equipped truck has "12V-N" stamped on the base. (12 volt, negative ground) This code is found on the right side of the reg as you look at the firewall, next to the screw that attaches it to the firewall.
Gord
1954 1/2 ton 235 4 speed
They do make 6volt alternators too but most go to 12 volt if going to the effort of changing. But check part number as suggested just to be sure.
40 Chevy 1/2 ton
6V alternator? They have to be pretty rare. What automotive application used that?
Here's another idea. Check to see if it has 12V headlights. Unless the vehicle was only used in the daytime, they would have to replace the headlights when they converted to 12V.
Gord
If it has a generator, the 12v generators are marked as such at the top of the oval "Delco-Remy" tag - at least every one I've seen was marked this way. None of my 6v generators are marked as to voltage.
1954 GMC De Luxe COE
Junior Member
Junior Member
Thanks, guys. I'll head out to the farm this afternoon and check a little closer.
5th Ave from the links section advertises a 6-volt alt. Not sure what the original applications are though. Changing from 6 to 12 is trivial anyway so not sure why anyone would go to all the trouble and expense to get modern but keep pushing 6 volts. but it's there if you want to.
40 Chevy 1/2 ton
I see what you mean, Dennis. I bet that they use a 12v core and drop the voltage to 6v in the internal regulator. The instructions mention that alternators weren't common until the 60's (after 6v systems were already obsolete).
I agree with you; why bother with a 6v alternator? You would have to ask someone who bought one.
Gord
Also look for a resistor between hot wire and coil. six volt system won't have one.
HERES THE EASY WAY, CHECK OUT THE TRUCKS BULBS HEADLIGHTS, TAILLIGHTS ETC. Heres a few #s
12 VOLT# 1156,1157,57,67,1895,2056,2057,53,89,90
6 VOLT# 63,1129,1154,55,51,87,63,81,82
I hope this helps you out!
1950 Chevy 3100
In the original Gallery
More pix and update in the Gallery Forums
1952 Chevy 1/2-Ton Deluxe Cab
1957 Chevy 210 4dr
1957 Chevy Belair 4dr
1964 Nova 400 4dr
V
V Offline
All good tips plus the original Delco generator tags were either red or black depending on 6 or 12 volts , of course I cannot right now recall which is which .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
Just use a 12 volt battery until you get it running and starting good. I used a 12 volt to get my 54 started so I could evaluate the engines condition, just didn't turn on any lights. It also helps it to start, after a long rest, if the engine cranks over faster.
Just my opinion,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Be careful, Scott. You can fry your fuel gauge starting a 6V truck with a 12V battery. It's on when the ignition is on.
Gord
I made a 6V alternator a while ago by changing the diodes and voltage regulator. I was having reliability problems and it worked for a while until I decided to convert to 12V. Parts are available on line, you can convert a GM 10si alternator to 6V for about $25. It worked pretty good until a short fried the regulator. I changed the harness and used a 12V alternator.
Paint & Body Shop moderator
