Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Tronman, Stewart2, MickeyP, 2 invisible), 144 guests, and 4 robots.
Topics128,288
Posts1,058,581
Members48,492
Page 84 of 177 1 2 … 82 83 84 85 86 … 176 177
Well I said I would try to post a picture of the interior of my '59.
I tried once to post and failed so trying again...
Interior so far
The Radio Delete Plate
was to coordinate with the colors of the Doors .
Still a project in process...
Wadayathink?
Jerry, I think your doing a great job. I like the contrast color to. Its amazing what just a little "zing" will do for one. Thanks for the pics.
Looks good from here, Jerry.
Love the color Jerry.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Sanded bed boards, repeat, repeat.
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
I have been trying to decide how I want to install a hood light I took out of an old Dodge van. I also fixed my power connect/cig lighter and under seat connects.
~Jim
Decided that I wanted a longer one piece door panel so I swapped this for this.
Robert C.
I'm a Genius in the making.
1950 3600
I have been working on the next motor to go in the truck while I rebuild the current motor.
http://s1296.beta.photobucket.com/u...tand_zps349063c1.jpg.html?sort=3&o=0
That's one HOT truck EC. lol
~Jim
If it ain't Blown, it Sucks !!!!-------Thumbs Up !!!!!
Brian
1955.2 3100 Truck
Jim That was not even funny. Tanks to all you fellow bolters and my forgiving wife for spending a little more time and money on the truck to get her back together. Still not laughing smile
Just read your second post. Ok now its funny. Thanks Jim
Almost done with the doors on the '59.
Got the glass installed:
http://s783.photobucket.com/albums/...tion=view&current=doorglass12813.jpg
Electric window regulators installed (not an easy task):
http://s783.photobucket.com/albums/...on=view&current=powerwindow12813.jpg
New door latches:
http://s783.photobucket.com/albums/...tion=view&current=doorlatch12813.jpg
And installed interior trim plate:
http://s783.photobucket.com/albums/...tion=view&current=innerdoor12813.jpg
Exterior trim tonight......
John drive
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
back yard wrench turner
John, looks like you will have it ready for the spring Turkey Run at Daytona.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
We'll be there to walk the in-field looking for parts, but I don't beleive the '59 will be ready by then. I'm hoping for June - that will be 18 months from the start of the project.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Ordered new smoothie wheels... clutch is on the way. Closing in on a tire choice...
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Its cold here today, so I stayed inside most of the day. However, I did go to the shop to install the new shiny pieces that arrived today from Brothers: inside rear view mirror and bracket, turn signal lever, and horn button. Still waiting on delivery of gauge cluster assembly.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Yeah OldB? But where are the pics???
~Jim
Got my rechromed '41 grill back and installed. Sure looks pretty.
cometman
Made a new barn door taillight "switch" or jamb contacts. http://www.bunchobikes.com/connector2.jpg
washed the truck .
Got the left side rear cab corner patch panel welded into place. Let me tell you, the fit of the patch panel was terrible and required a lot of message work. In the end, the door jamb edge ended up not straight with the rest of the door jamb and wll require metal fillers to bring back to straight. I had none of these problems with the right side patch panel source from same supplier. Wore out my wrist using my slapping bar to message the panel curves where they needed to be. Will work on front left lower cab corner next.
Hey Bolters! Over the weekend I pulled the carb off my '54 1 Ton
chev. Have it apart and soaking in the sauce!!! I picked up the carb kit, $11.00 bucks!!! (God, some parts are really cheap to get)
My truck was sitting for 5-7 years, then my buddy gave it to me. (he has too many projects on the go!) I bought coil,plugs,cap,rotor,points,condenser,fuel pump for less than $150.00!
And 6volt too. We pulled the fuel pickup out of the tank and unplugged it. Then,....it ran. Here is the my first run a couple months ago.
I have acquired 1 fender for it, $100 bux. And just yesterday started pulling apart the flat deck.
This truck was an on site welders truck beside the concrete plant I worked at. Long story short, the land was expropriated and the pipe coating company behind us, sold and the welder gave this truck to my friend. Then gave it to me.
I am semi restoring it, as to drive it as much as I can.
Will try to keep an update on it.
Thanks, and KEEP ON ROLLIN!!!
After a snag, I finally got the turn signal assembly together (with the help of Bolter Red58) and installed it onto the steering column of the '59.
Over the weekend I reworked and installed the gas tank!
More forward progress... a good thing!
Originally Posted by cometman98006
Got my rechromed '41 l back and installed. Sure looks pretty.
And Pics, where are the pics?
~Jim
Well work has kept me from working on my truck until tomorrow. If things go as planned I am going to be able to drive it under its own power again (well at least in the parking lot). Bleed breaks hook up gas linkage coolant you all the last min stuff.
Installed the seat belts in the '59 last night. Tonight it's back to sanding, and sanding, and sanding....
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Got the remainder of the rotted plywood sheet and rusted strips cut out using bolt cutters and I replaced the starter with a reman unit and main power cable w/ the cloth covered #1 from Jim Carter. She starts up just fine now! Still need to get another length of #0 cable and ring terminals tho so I can add the cutoff switch in. ...couldn't bring myself to cut up the expensive cable even tho it's plenty long.
Make sure your cut-off switch is rated for the high amprage 6v system, otherwise it will be the cause of low current flow.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Had a long day yesterday but I had a few minutes to work on the 'Burb, so I installed the barn door post contact. Now I'll take the door side and add some wire to connect to the light itself. Then a quick test to see how well that door grounds through the hinges and latches.
Got the front clip dissasembled yesterday!
Not a fan of the upper outer grill screws...
Also got the running boards and front bumper off.
Pics and details at my blog link below.
Next week I'm going to try and get the engine out...
Big Bolt Forum Co-moderator
I saw your blog. Someone made a comment about the radiator not looking Chevy, it doesn't look like my 48's rad. Do you think it is original?
1948 Chevy 2-Ton
Put the cab on the frame set the motor in with bell housing mach up V8 mountsjavascript:void(0);
A 85 disk brake first member mated to a 63 frame 62 cab 60 283 out of C-30 pulpwood truck http://s1308.beta.photobucket.com/user/mutttruck/media/P2070031_zps139e81d9.jpg.html?sort=3&o=14
so far i have i have votes for gmc or studebaker...
im thinking its a 58ish gmc rad and a 48ish core support
Put a coat of spar urethane on the boards that go half way up on the inside walls of my panel.
Made some 1" spacers to move the top of the seatback cushion out on my stock 38 seat. Felt a lot more comfortable - but only drove around the block.
Won my 1st trophy today at Cars for Cure by American Lung Association. smile
the trophy was for 'Most Unique'.
The show has been mostly high end sports cars and I entered my truck to see how it would be received.
Wayne
1989 Silverado
Rebuilt carb.
Truck was hard to start before.
It started right up. Yea.
It could of been the warm weather. We did break freezing today. I hope it was rebuilding the carb. It doesn't weep gas like it did before.
Lost
1952 Chevy 3/4 ton
1948 Simplex Motorcycle
1930 Ford Model A Coupe
1928 Ford Model A Station Wagon
