8 members (wvstovebolt, 1955 1 Series, SuperSport, ‘37ChevyPU, tclederman, Gray_Ghost, Cletus1950, 78buckshot), 49 guests, and 3 robots.
Topics128,129
Posts1,056,697
Members48,454
Hello all, I am new here. First post actually.
I used to be a Thirdgen Camaro guy until I decided to give up on the project. (Long story)
Anyways, here is the truck that I am 98.9378% ready to purchase from a family member for a good price. I have been eyeing this thing over for more than a decade.
It's a 1948 Chevy truck with live tandems.
I have been researching this truck on google, but according to that "wise" website, none exist.
http://i49.tinypic.com/2z6t9va.jpg
http://i50.tinypic.com/oa3ers.jpg
http://i49.tinypic.com/23i87s6.jpg
Live tandems were't available from the Factory on Chevrolet trucks until 1956. Tandem conversions were available though, but only from upfitters such as Trucktor, Truckstell, Fabco etc. I had a 1954 Chevrolet COE that had a chaindrive Trucktor Tandem conversion installed on it when new. If you get a chance try to search the rear frame, & axles for a Tag with one of these names on it. I'd like to see pictures of the tandem section. Cool truck.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Cool truck, many ten wheelers of that era were just had a dead axle added, so your potential project is a bit more unusual. One of the site members bought a chevy with a crane mounted and tandem conversion a few years ago but you don't see them often.
So, did this modification require lengthening the frame? I see pictures of both long and short frames floating around on the internet.
I will post updates when they happen.
One more question. How much do these things weigh with nothing on the rear frame? Ballpark, I'd like to know in order to plan to trailer it down to my house.
On my '54 COE the Trucktor Tandem consisted of it's own frame extension that actually slide over top of the Factory frame.
Spanky Hardy
1950 GMC 250 1-Ton
Ace,
I'll take a stab at the weight...
The 6400 Cab and Chassis has a curb weight of a little less than 5,000 pounds. The extra rear, springs and tires will add about 1,000 pounds...my guess puts it at about 6,000 pounds total.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I would estimate the weight a little higher than that. We used to figure about 1500 lbs. by adding a drag axle. A screw would probably add more like 2000 with third member, interaxle driver shaft and it looks like pretty heavy springs. It may have added 2500 lbs.
So, after Spanky's reply, I got a little excited. The truck is currently in Northern Wisconsin. Spanky's comment of "Fabco" was very interesting to me. I'll save that for later.
Any ideas on the frame for where the tags would be located? Most likely on the rear end, near the split in the frame or somewhere more protected. I've heard Glovebox as well.
Would this upgrade have been based off of the Deuce and a Half with regards to running gear?
On my Trucktor conversion the ID tag was rivited to the last crossmember facing rearward. Grico, Thornton, & Truxmore were a few more upfitters listed in my Chevrolet "Silver Book" that supplied Chevrolet with Tandem conversions.
Spanky Hardy
1950 GMC 250 1-Ton
As someone above stated "one of the members a few years ago bought a Chevy with a tandem and a crane mouinted".
I am the guy. The only current photos I have of it are on my Picturetrail account linked below. It's got a Truckstell unit on it. Good luck with yours.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Hi there, I have a trucktor tandem axle assy. from the back of the cab, it is all there, there is a plate riveted on the back of the tag axle. It has the 8 rims and tires still on the assy. I have pictures of the set up if you would like to see them, it is like Spanky says, the aftermarket frame just slips over the original frame rails, mine has the chain set equalizer with the sprocket in the middle. This came off a 1948 Chev. truck with a long wheel base. Thanks, Harold in Penna. my number is 610-767-8370 if needed.
Hey,53moneypit1 Is that a Schield Bantam,or a Truckstell unit? just wondering. My assistant- manager's uncle was Vern Schield,and he built his first truck-mounted crane back in about 1932,out of old thrasher and steam-shovel parts.He owned about three limestone quarries in the Waverly,Iowa area. his truck became popular quickly!A lot of Bantams used during WW-2. usually mounted on G.M.C. C.C.K.W's.Either 1/2-cab,or no-cab.I think your unit is rare.Don't see too many 1/2-cab Chev's. Mostly I.H.C.'s.,from that era,up into the mid-'50's,when most of the crane mfr's. adapted to the truck cranes that we see today. Nice find!! Any up-dates??
Mo' Tater
1 Offline
If it's a live tandem how do the drive lines connect to the differentials without a transfer case? Or is it chain drive connection?
1936 Chevrolet 1.5-ton SWB
"Murtahg"
More pix on Photobucket
It's only original once.
1 Offline
I guess what I'm wondering is why didn't GM or Chevrolet use the same technology as the military trucks when it came to live axle tandems of the 1940's, with the transfer case and pillow block set up? A gear ratio change could of made them more road friendly. Did GM ever make a road tractor with 2 live axles for civilian use in the 40's?
"Murtahg"
3B Offline
Hy 1936only, as far as I know, for civilian use "Chevrolet" never offered a factory live tandem truck in the forties. GMC however did offer such trucks, one thing that we may forget is that civilian truck production was severley curtailed during World War Two. When you ask a question about "GM" you are asking about all the divisions, hope that helps.
I have a Canadian Sales truck book and it has a number of advertisements with illustrations of these conversions. When I think of moving all that weight with those little old motors it really amazes me.
53Moneypit
Would I ever love to see pictures of that half cab. That is some piece of work.
1951 1 Ton Completed
1 Offline
So basically most of the civilian frieght/produce was moved with single axel 20's to 30's trucks in the 1.5 to 2 ton range. Amazing, how they used the low horse power Stovebolt six's and GMC's to keep commerce going. When I drive my wifes '36 around I can't imagine pulling a big load up a grade without going into 1st gear and crawling along at 10 mph. For those of you out there in Stovebolt land that have not actually driven one of these trucks, I invite you to do so as soon as possible to really appriciate what your restoring. I sure do now.
"Murtahg"
Rick, most folks don't stop to think that those days were much slower times with low speeds on poor roads, no "just in time" production then, things got delivered in weeks, not days wink
every time I drove my 46 1.5T my mind wandered back to the 'iron men' who built our world with those trucks, and who mostly wound up disabled from the pounding they took driving them - just think about 12-15 hours on that suspension over rough roads in the days before the interstate highway system eek
1 Offline
Bill, I'm 6'4" and I have to slouch down and have my arm hang out the window and my head is within an inch of the headliner when I drive the '36. How did they do it? I still have perma-grin though everytime I get in it. Can't wait to get my '43 6x6 tractor running to feel what an old school live tandem axle rig is like.
"Murtahg"
