0 members (),
128
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Well I got my cab and front fenders off yesterday...
I'm Pretty excited at my progress!
For those interested there are some links to pictures at my blog below. Im trying to get better at writing some on there so that I have a story when im done with all of this...
So all I have left is a frame and 2 axles with an engine and steering column...
I think im going to dissasemble the front fenders from the core support to get those parts out of the way but then I'll pull engine. Any advice of sequence? Pull transmission first? I will have an engine stand to mount that to.
I also have to cut all of the junk from a cobbed together hoist frame off the rear as well. I plan to put one back on but this is beyond repair. it looks liek any scrap of metal the PO could find was slapped on and poorly welded in place...
Question about core support: From reading on here I expected two bolts from the frame cross member into the core support. My truck had only one bolt centered. does this mean anything? | | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | Keep up the excitment Tj M, I've been where your at a few times. I'd pull the trans and engine as a unit and take down the trans on the floor, just my way of doing these.I've cut off over 750#'s of steel trusses and brackets and other who knows what steel welded on the frame.I think the suspension came up an inch or so.My 53 GMC 2 ton had 2 core support bolts. Good work,...I love the smell of all the grease and stuff when you tear these trucks down. I wonder if there is a after shave that smells like that? | | | | | Joined: Jun 2011 Posts: 63 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 63 | I love the smell of all the grease and stuff when you tear these trucks down. I wonder if there is a after shave that smells like that?[/quote] Wouldn't that be cool? Maybe with a hint of WD-40 :-) | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....siliKroil smells the best. LOL
I read once where a bolter told of having the "while I'm here syndrome". while I'm here I might as well fix this!!.... and ends up like you, with an off frame resto. Keep plugging.... a minimun of 15 minutes a day, no matter what. And keep us posted. | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | I know what you mean...
Mine is more of a.. Not much choice...
I was originally thinking I'd get it serviceable to drive it some even if just around the friends farm for a while before diving in head first... unfortunatly, it just didn't make sense. The cab floor was so far gone it sagged and impeded the pedals and the brakes were non-existant. | | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | Tj M,
Nothing like jumping in with both feet! And you did look before you leaped! Any plan can be tackled as long as you have a sound plan to start with. I am at a crossroad as I am contemplating frame off vs. creeper time. Though mine runs, moves, and stops, needed repairs, cleanup, and detailing would be much easier with out the body in the way!
As far as the aroma, the grease and oils are o.k., but I prefer the mud, primer, and paint! They could call the aftershave "The Shop" or "Restore"!
Good luck and keep us posted on progress! | | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | Hey Tj_M, I forgot to tell you if you pull the engine and trans as a unit be sure to take out the 2 lower bolts that hold the trans on that are inside the bellhousing while it's in the air. The upper ones are outside. | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | nice... I know what you mean by frame off here is mine a few months back Huckster: Frame Off and where i was as a few weeks aog on the frame: Huckster: Frame Prime 03need to finish up the prime, and start on the suspension and members, then i can paint !! 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Thanks all for the encouragement!
1936only: Can you please explain? are the bottom two inside an inspection widnow or something? just easier to get to?
Maybe i'll break all the bolts loose while it's still in the frame...
Can I set the engine square on the ground? should I be concerned about crushing the oil pan? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | those bolts are only accessible from inside the bellhousing once the lower cover is off, once the engine is on the ground you won't be able to get at them .... as long as you don't drop it, setting the engine on the ground, wedged so it's not tippy, will be fine
Bill | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | good to know!
I'll prob crack everything loose and remove the bottom two and then pull the engine.
Then I can remove the transmission and get the engine on the stand.
I can search too but how about lift points?
Tj
| | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | I can search too but how about lift points?
Tj i used a few grade 8 bolts through the head into the block. i think thats a common way to attatch a chain when pulling the motor.
| | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | You can get at the 2 lower bolts by taking off the inspection cover on the bottom of the bellhousing. You'll see 2 bolt heads attaching the trans to the bell housing. And you can take these out or just loosen them up while the engine and trans is in the truck. I usually have a couple of 2x4's around to put the engine down on and stabalize it but I would'nt just take the cherry picker off of it while your working on getting the trans off. I would recomend a engine stand to bolt your engine to while you work on it. Much safer than having an engine fall over and ruin your day. | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | I'm going to borrow an engine stand from my uncle so I have that covered.
I found other threads about using the head bolts. I may actually buy a couple lifting eyes or eye bolts. Then I'll have good attachemnt points.
Anyone know which positions are good for balance? Otherwise I'll eyeball it.. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I'm going to borrow an engine stand from my uncle so I have that covered.
I found other threads about using the head bolts. I may actually buy a couple lifting eyes or eye bolts. Then I'll have good attachment points.
Anyone know which positions are good for balance? Otherwise I'll eyeball it.. The on-line 1954 truck manual (if you do not have a hard copy of that manual) shows the recommended lift points. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | This has morphed into an engine topic. | | |
