5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
I have the proper bell housing now for our '50 3100, however it has a shaft for a three speed that I would like to remove. How is that done?
Thanks!
Michael
Riding in the Passing Lane
Boy! I don't understand what you mean by a shft from a 3 speed. The 3 speed & 4 speed use the same bell houseing.
1972 Chevy c10 Cheyenne Super
The lug is pressed into the housing I would think you can't tap it out with a hammer (carefully) failing that you could always grind it off.
ODSS Lawman
ODSS Lawman
Are you referring to an alignment pin?
Can you send us a link of a picture?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
On the three speed bell housing there is a pressed in lug the linkage pivots off of. It is about 3/4" dia. and sticks out from the bell housing about 1"
That is it Brad-so it is pressed in...Thanks! Now we know better how to approach removing it. From the inside it almost looks like threads.
Michael and Jacob Savage
You know, we hated to think about grinding it off but in the end it might be better than having an extra hole there or maybe busting the casting with too much determination to remove the thing. Plus, we hate ruining anything..you never know when you might need it!
I would agree with grinding it off as being the least risky of the two. Taking a hammer to anything cast and 60 years old could be problematic. You see a similar pin on the SM-420 transmissions on trucks with the driveshaft brake. I have always wondered about the best way to remove them. You can see it here in this picture, don't have one of the bellhousing but they both press fit.
http://www.flickr.com/photos/advance-design_parts_co/8417815389/in/photostream
