7 members (55shaker, Tim Canfield, moparguy, Hotrod Lincoln, Gdads51, Bill Hanlon, treegrower),
132
0
Mod | | | Forums66 Topics128,195 Posts1,057,380 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 12 New Guy | | New Guy Joined: Mar 2012 Posts: 12 | I have the proper bell housing now for our '50 3100, however it has a shaft for a three speed that I would like to remove. How is that done?
Thanks!
Michael | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Boy! I don't understand what you mean by a shft from a 3 speed. The 3 speed & 4 speed use the same bell houseing. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The lug is pressed into the housing I would think you can't tap it out with a hammer (carefully) failing that you could always grind it off. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Are you referring to an alignment pin?
Can you send us a link of a picture?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | On the three speed bell housing there is a pressed in lug the linkage pivots off of. It is about 3/4" dia. and sticks out from the bell housing about 1" | | | | | Joined: Mar 2012 Posts: 12 New Guy | | New Guy Joined: Mar 2012 Posts: 12 | That is it Brad-so it is pressed in...Thanks! Now we know better how to approach removing it. From the inside it almost looks like threads.
Michael and Jacob Savage | | | | | Joined: Mar 2012 Posts: 12 New Guy | | New Guy Joined: Mar 2012 Posts: 12 | You know, we hated to think about grinding it off but in the end it might be better than having an extra hole there or maybe busting the casting with too much determination to remove the thing. Plus, we hate ruining anything..you never know when you might need it! | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I would agree with grinding it off as being the least risky of the two. Taking a hammer to anything cast and 60 years old could be problematic. You see a similar pin on the SM-420 transmissions on trucks with the driveshaft brake. I have always wondered about the best way to remove them. You can see it here in this picture, don't have one of the bellhousing but they both press fit. http://www.flickr.com/photos/advance-design_parts_co/8417815389/in/photostream | | |
