8 members (Lightholder's Dad, Otto Skorzeny, Peggy M, 5cameo8, MNSmith, TUTS 59, 2 invisible), 125 guests, and 3 robots.
Topics128,088
Posts1,056,380
Members48,442
Trying to find out what year doors will fit on a '36 cab, '37 and '38 ??
1939 Chevy 1/2-Ton Pickup Truck
More pix on Photobucket
1946 1.5-Ton Chevrolet Stake Bed
1940 Chevy Sedan - Frame-off Restoration
Short cab '36 wil be really close to a '37-'38. Can not say for sure if they are the same, but just looking at them I would say yes.
Joe
1 Offline
Hello Dynosaurus, I have used a '37 GMC door on a '36 Low Cab. It fits, don't know about '38.
1936 Chevrolet 1.5-ton SWB
"Murtahg"
It's only original once.
1 Offline
Hey, after thinking and looking at some pics, looks like the same body lines on '36. '37, '38 I'm thinking they all interchange.
"Murtahg"
That's what I like to hear...Thanks for the info. Now if I can just find one of them, I'll be set.
Looks like all the cabs I have seen, rust in the front corners and the rear corners bent in. The '36 uses a different windshield then the 7 or 8, it has a different arc across the bottom or in the corners, I believe the top is the same. Doors should bolt right on, inside is all the same. Its for sure not a '38, they filled the fuel tank from the outside, and I believe '36 did to. I thought '37 was a one year only with fuel fill under seat, so maybe thats what it really is.
Joe
...joe is correct about 37 being a one year item with the split bottom seat so you could raise the passenger side seat and put gas in. I do it all the time!
The VIN on this one says it's a '36. I have never looked inside the door jamb of a '37, but this one has wood from the floor up thru the A-Pillar. Do the '37s have wood where the door hinges mount also ???
1 Offline
My '36 had the split seats and the fuel fill under the seat, I wonder if it was a late '36 or something. My brothers '36 has the gas fill neck outside the one oiece seats.
"Murtahg"
The only wood in a '37 was under the floor on each side holding the cowl area to the floor. Maybe 8" total of wood, it was flex joint.
Joe
