3 members (68ironhead, Jay R, WICruiser), 144 guests, and 2 robots.
Topics128,056
Posts1,055,796
#909479 01/07/2013 1:30 PM
Ok, another one...
I am planning on converting my COE to 12v with a 12v starter and matching flywheel. BUT, I want to keep the foot pedal starter. I was thinking of connection the foot pedal to a switch to control the starter solenoid. Has anyone done this before?
1947 First Series Chevy 2 ton COE
2005 - It started in the Gallery
2023 - Follow the restoration in my Project Journal
1962 IH Scout 80
1982 Chevy Caprice Classic
You don't have to change out the 6v starter when you convert to 12v.
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
I would and have just run the original starter on 12V, never had a problem and drove my truck every day for a few years.
If you crank it for minutes at a time the 6v starter on 12V will be an issue, but if you have to crank it that long you already have issues...
Keep it simple and use what you already have, it's not that hard on the starter for a few seconds at a time and if it dies they're cheap (used) and real easy to replace.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
You also have option of switching to the 12v flywheel and a 12v foot-actuated starter (used up to 1959).
Oooh! 12v foot operated starter!
There was another post somewhere that said if you run 12v on the 6v starter it will burn out eventually. I guess that one scared me off. But I might consider keeping the starter and running it 12v since it seems to work OK for others.
1962 IH Scout 80
ODSS President
ODSS President
Well, I'm a daily driver ONLY vehicle as below and have 12 years of pushing 12 volts into a (the same one) 6 volt starter.
Regards,
Cosmo
~ Cosmo
1949 Chevy Half Ton
My 1961 261 had a mechanical foot starter. Now in the old '46, been using the original 216 6v starter (all 216 bellhousing, flywheel etc) for 20+ years without fail. I opted for the old foot starter since just about all my starter probs were related to a solenoid failure.
1946 1/2-Ton Chevy
Thanks everyone for your help.
I think I'll try keeping the 6v starter and associated parts and run 12v to it. Now I have to clean and paint all those parts. smile
1962 IH Scout 80
Farmdog #911330 01/13/2013 12:23 PM
It cost me $8 to have my 6V starter foot starter "rebuilt' at the local auto electric shop..= new brushes only after 5 years of 12V. So why go to all the trouble of changing it. More concern will be the heater fan which will run 300 mph on 12V.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Riding in the Passing Lane
A 6 volt starter will last longer on 12 volts then it will on 6.
1972 Chevy c10 Cheyenne Super
Not sure I agree or perhaps understand. If one has starting issues and overheats the 6V starter I think it will fail quicker. Please explain why you feel they will last longer.
Dave
